Post up your Rit dye projects..
Re: Post up your Rit dye projects..
Is it boiling? Haven't had this issue with FRN. Have not tried the FRCP. Did have an issue with the Polestar G10, but I cranked up the heat and it solved it.
I always use half the bottle if I’m doing one color lol. High heat, half a bottle, small stainless pan 3/4 way with water. Usually takes 5-10 minutes for FRN. 10-20 for G10. Never tried FRCP.
Very nice color after an additional 1.5 hours at a 7:1 ratio. I can't seem to figure out how to post a picture here, even in full editor mode.
I use a couple tablespoons and an inch of water.
The entire dying process for dying a salt knife a single color takes me 10 minutes.
I guess I overuse. Like when I cook with salt. Needs more
Finally dyed the manix salt. First time trying a lighter color (not black) on frcp, and it was interesting. First attempt i was going for more of a gold or caramel color with sandstone dyemore. I got it, but it showed every imperfection from the scale molds including the injection spots. It was all blotchy on the smooth parts. It annoyed me enough, that i scotchbrighted it smooth and increased the dye ratio a little. Also upped the temp from 200 to a rolling boil, and let it go darker. Got this, and its growing on me. Some of the yellow peaks from underneath giving it sort of a bronze effect. May strip it off and keep it yellow, or go black eventually. We'll see.
I actually think that looks really cool and wouldn't change it a bit! What color did you use?
for science! thanks for sharing windward!
- cabfrank
I agree with Jeff. It looks fantastic.
How long was it boiling? Did it change the fit of the parts? When I did the really long soak time at boiling/close to boiling temperature, I think it slightly warped the scales, as they do not fit together quite like they did when they were new.Windward wrote: ↑Sat Dec 30, 2023 10:31 amFinally dyed the manix salt. First time trying a lighter color (not black) on frcp, and it was interesting. First attempt i was going for more of a gold or caramel color with sandstone dyemore. I got it, but it showed every imperfection from the scale molds including the injection spots. It was all blotchy on the smooth parts. It annoyed me enough, that i scotchbrighted it smooth and increased the dye ratio a little. Also upped the temp from 200 to a rolling boil, and let it go darker. Got this, and its growing on me. Some of the yellow peaks from underneath giving it sort of a bronze effect. May strip it off and keep it yellow, or go black eventually. We'll see.
First go around, about 3 minutes. When i re-did it again it wasn't more than 5 mins. No warping issues, but i only took it apart on the first attempt. Second try i just dumped the whole knife in, like i do with all salts. Figured if it couldnt handle a few mins in dye, then it wouldn't my day-to-day saltwater exposure work days much either.Chumango wrote: ↑Sat Dec 30, 2023 6:04 pmHow long was it boiling? Did it change the fit of the parts? When I did the really long soak time at boiling/close to boiling temperature, I think it slightly warped the scales, as they do not fit together quite like they did when they were new.Windward wrote: ↑Sat Dec 30, 2023 10:31 amFinally dyed the manix salt. First time trying a lighter color (not black) on frcp, and it was interesting. First attempt i was going for more of a gold or caramel color with sandstone dyemore. I got it, but it showed every imperfection from the scale molds including the injection spots. It was all blotchy on the smooth parts. It annoyed me enough, that i scotchbrighted it smooth and increased the dye ratio a little. Also upped the temp from 200 to a rolling boil, and let it go darker. Got this, and its growing on me. Some of the yellow peaks from underneath giving it sort of a bronze effect. May strip it off and keep it yellow, or go black eventually. We'll see.
Wow. I agree, that does look super cool Windward!
Thanks for posting & sharing
u.w.
u.w.
I like it too!
dyed my Stretch XL Salt.
1/3 cup of sage dye, 6 cups warm water, 1 tablespoon white vinegar. brought a sauce pot to a rolling boil then did 10x 3 second soaks.
The color looked really dark in the pot, guess I used more dye than I needed.
30 seconds gave a decent coat. The logo pads came out a little yellow but I'll live.
Here it is next to my OD green 4 max:
Proceeded to use the knife to make lemonade:
Here it is next to some Pacific Salts. Top knife is dark green, stretch is sage, bottom is kelly green:
Much happier with it now. I appreciate the function of the yellow handles but man they're ugly Really pleased with the shade of green the Sage color gave it.
Saved the dye in a mason jar because I plan to do it again someday. Like I mentioned the logo pads look a little yellow still, but I was also afraid of soaking it too long and having it come out like the dark green.
Looks great vivi, that color might have to be on my shortlist for next dye session
Nice job.
Just a curiosity...
How might it work to use a small model paint brush to selectively apply more dye to just the logo area? It may allow for darkening that area without affecting the rest of the handle.
