Post up your Rit dye projects..
Re: Post up your Rit dye projects..
Is it boiling? Haven't had this issue with FRN. Have not tried the FRCP. Did have an issue with the Polestar G10, but I cranked up the heat and it solved it.
I always use half the bottle if I’m doing one color lol. High heat, half a bottle, small stainless pan 3/4 way with water. Usually takes 5-10 minutes for FRN. 10-20 for G10. Never tried FRCP.
Very nice color after an additional 1.5 hours at a 7:1 ratio. I can't seem to figure out how to post a picture here, even in full editor mode.
I use a couple tablespoons and an inch of water.
The entire dying process for dying a salt knife a single color takes me 10 minutes.
![unicorn :unicorn](./images/smilies/unicorn.png)
Finally dyed the manix salt. First time trying a lighter color (not black) on frcp, and it was interesting. First attempt i was going for more of a gold or caramel color with sandstone dyemore. I got it, but it showed every imperfection from the scale molds including the injection spots. It was all blotchy on the smooth parts. It annoyed me enough, that i scotchbrighted it smooth and increased the dye ratio a little. Also upped the temp from 200 to a rolling boil, and let it go darker. Got this, and its growing on me. Some of the yellow peaks from underneath giving it sort of a bronze effect. May strip it off and keep it yellow, or go black eventually. We'll see.
![Image](https://i.postimg.cc/T3ZB5pdY/PSX-20231230-112246.jpg)
I actually think that looks really cool and wouldn't change it a bit! What color did you use?
for science! thanks for sharing windward!
- cabfrank
I agree with Jeff. It looks fantastic.
How long was it boiling? Did it change the fit of the parts? When I did the really long soak time at boiling/close to boiling temperature, I think it slightly warped the scales, as they do not fit together quite like they did when they were new.Windward wrote: ↑Sat Dec 30, 2023 10:31 amFinally dyed the manix salt. First time trying a lighter color (not black) on frcp, and it was interesting. First attempt i was going for more of a gold or caramel color with sandstone dyemore. I got it, but it showed every imperfection from the scale molds including the injection spots. It was all blotchy on the smooth parts. It annoyed me enough, that i scotchbrighted it smooth and increased the dye ratio a little. Also upped the temp from 200 to a rolling boil, and let it go darker. Got this, and its growing on me. Some of the yellow peaks from underneath giving it sort of a bronze effect. May strip it off and keep it yellow, or go black eventually. We'll see.
First go around, about 3 minutes. When i re-did it again it wasn't more than 5 mins. No warping issues, but i only took it apart on the first attempt. Second try i just dumped the whole knife in, like i do with all salts. Figured if it couldnt handle a few mins in dye, then it wouldn't my day-to-day saltwater exposure work days much either.Chumango wrote: ↑Sat Dec 30, 2023 6:04 pmHow long was it boiling? Did it change the fit of the parts? When I did the really long soak time at boiling/close to boiling temperature, I think it slightly warped the scales, as they do not fit together quite like they did when they were new.Windward wrote: ↑Sat Dec 30, 2023 10:31 amFinally dyed the manix salt. First time trying a lighter color (not black) on frcp, and it was interesting. First attempt i was going for more of a gold or caramel color with sandstone dyemore. I got it, but it showed every imperfection from the scale molds including the injection spots. It was all blotchy on the smooth parts. It annoyed me enough, that i scotchbrighted it smooth and increased the dye ratio a little. Also upped the temp from 200 to a rolling boil, and let it go darker. Got this, and its growing on me. Some of the yellow peaks from underneath giving it sort of a bronze effect. May strip it off and keep it yellow, or go black eventually. We'll see.
Wow. I agree, that does look super cool Windward!
Thanks for posting & sharing
u.w.
u.w.
I like it too!
dyed my Stretch XL Salt.
![Image](https://i.postimg.cc/wMcfRJ0Z/20240102-223124.jpg)
1/3 cup of sage dye, 6 cups warm water, 1 tablespoon white vinegar. brought a sauce pot to a rolling boil then did 10x 3 second soaks.
![Image](https://i.postimg.cc/pdX0hpF1/20240102-213655.jpg)
The color looked really dark in the pot, guess I used more dye than I needed.
![Image](https://i.postimg.cc/BZ8VBLwr/20240102-214419.jpg)
30 seconds gave a decent coat. The logo pads came out a little yellow but I'll live.
![Image](https://i.postimg.cc/qvGbv8z3/20240102-214546.jpg)
![Image](https://i.postimg.cc/BZ1mKWjs/20240102-214607.jpg)
![Image](https://i.postimg.cc/TwKC0FQV/20240102-214624.jpg)
Here it is next to my OD green 4 max:
![Image](https://i.postimg.cc/QM4fphgN/20240102-214501.jpg)
![Image](https://i.postimg.cc/90T1596z/20240102-214517.jpg)
Proceeded to use the knife to make lemonade:
![Image](https://i.postimg.cc/L6LQrdSv/20240102-215100.jpg)
![Image](https://i.postimg.cc/0yvXvt2v/20240102-215201.jpg)
Here it is next to some Pacific Salts. Top knife is dark green, stretch is sage, bottom is kelly green:
![Image](https://i.postimg.cc/Jhxzxdtz/20240102-223708.jpg)
Much happier with it now. I appreciate the function of the yellow handles but man they're ugly
Really pleased with the shade of green the Sage color gave it.
Saved the dye in a mason jar because I plan to do it again someday. Like I mentioned the logo pads look a little yellow still, but I was also afraid of soaking it too long and having it come out like the dark green.
![ROFL :rofl](./images/smilies/rolling-on-the-floor-laughing.png)
Looks great vivi, that color might have to be on my shortlist for next dye session
Nice job.
Just a curiosity...
How might it work to use a small model paint brush to selectively apply more dye to just the logo area? It may allow for darkening that area without affecting the rest of the handle.
