Chief Crucarta
Re: Chief Crucarta
Looks really good!
- Brock O Lee
Re: Chief Crucarta
Bronze washers are visible on both sides through the pocket clip holes. Stock photo from KnifeCenter.Red Leader wrote: ↑Tue Aug 26, 2025 9:27 pmI looked reeeeal close at the action of this one because it was a little gritty and I was trying to figure out if it was coming from the blade/lock friction or more of the side friction.
I 100% saw a bronze washer in there, but my eyes didn’t make out if there was one on the other side. Very well could have been, and makes a lot of sense that if there is one, there should be two, I just couldn’t tell.
I also heard that the regular Native 5 crucartas may be coming as early as the end of this week, and while it might be a wild rumor…best to keep your eyes open.
Re: Chief Crucarta
Someone confirmed they were linerless when I asked a while back. Kinda surprised me as Spyderco deemed micarta too flexy without a considerable retooling of full liners for the PM2 and M2. I'm guessing they employed some seriously ridged version of micarta for this model.
Re: Chief Crucarta
abbazaba wrote: ↑Wed Aug 27, 2025 9:50 amSomeone confirmed they were linerless when I asked a while back. Kinda surprised me as Spyderco deemed micarta too flexy without a considerable retooling of full liners for the PM2 and M2. I'm guessing they employed some seriously ridged version of micarta for this model.
It must have something to do with milling the scales out for nested liners vs leaving them at full thickness for a linerless design. I think it's a different situation with a back lock vs a compression lock where you either need to nest the liner with the lock bar or have a full liner. There's surely some strength difference between G10 and Micarta but I'm betting you'd still shear of screws or snap the blade before you verify which is weaker of the two.
Red Leader
Re: Chief Crucarta
That’s what came to my mind as well. You’d have to have an internal cutout for the compression lockbar, and perhaps Spyderco deemed it too much a compromise on a compression lock without full liners.Evil D wrote: ↑Wed Aug 27, 2025 10:07 amabbazaba wrote: ↑Wed Aug 27, 2025 9:50 amSomeone confirmed they were linerless when I asked a while back. Kinda surprised me as Spyderco deemed micarta too flexy without a considerable retooling of full liners for the PM2 and M2. I'm guessing they employed some seriously ridged version of micarta for this model.
It must have something to do with milling the scales out for nested liners vs leaving them at full thickness for a linerless design. I think it's a different situation with a back lock vs a compression lock where you either need to nest the liner with the lock bar or have a full liner. There's surely some strength difference between G10 and Micarta but I'm betting you'd still sheer of screws or snap the blade before you verify which is weaker of the two.
Re: Chief Crucarta
I paid for the shipping upgrade so mine should arrive tomorrow. Probably won't be able to get the package until I get back from an event in the evening but I'll post some impressions & images tomorrow night.
yablanowitz
Re: Chief Crucarta
Helicoils are used to repair stripped threads. Basically, it is a coil of spring wire threaded into a hole with worn or stripped threads and left there to form new threads. I imagine they use threaded inserts rather than helicoils for this application.
Re: Chief Crucarta
yablanowitz wrote: ↑Wed Aug 27, 2025 8:03 pmHelicoils are used to repair stripped threads. Basically, it is a coil of spring wire threaded into a hole with worn or stripped threads and left there to form new threads. I imagine they use threaded inserts rather than helicoils for this application.
Yeah, that. Helicoils is not the correct term, they're not exactly the same thing. They're using some kind of threaded insert.
Re: Chief Crucarta
Here in the ole Crash'em up industry we call them either Nutserts or Rivnuts, being down South it's more Nutserts.Evil D wrote: ↑Thu Aug 28, 2025 4:33 amyablanowitz wrote: ↑Wed Aug 27, 2025 8:03 pmHelicoils are used to repair stripped threads. Basically, it is a coil of spring wire threaded into a hole with worn or stripped threads and left there to form new threads. I imagine they use threaded inserts rather than helicoils for this application.
Re: Chief Crucarta
Just got mine in this afternoon. You can tell this model is gonna have some funny centering issues just because of the micarta w/o liners, but nothing worse than what happens on the LW models. Overall much better feel than the LW thanks to PB washers and much more comfortable scales, but not giving up much weight, still feels super light for a knife this size. Action will definitely need a bit of breaking in; not feeling anything gritty, helps to add a drop of Nano-Oil to the lock face area. Overall feels worth the wait so far.
Re: Chief Crucarta
Received one today. Some measurements:
Handle thickness:
XHP 11.35mm
S90V 11.35mm
Cruwear 11.39mm
Weight:
XHP 113 grams
S90V 103 grams
Cruwear 107 grams
- Naperville
Re: Chief Crucarta
I received mine yesterday. The scales are very stiff, almost zero give in them when grasping the knife to make them deflect.
Very nice knife!
Very nice knife!
Re: Chief Crucarta
I'd rather have an ACT with such steel. I don't like shaggy micarta
Re: Chief Crucarta
Hi Gears_QQQ,
Welcome to our forum.
- Manixguy@1994
Re: Chief Crucarta
Glad you posted Illinois native ! Stiffness of handle was a concern for me . Definitely will give the Chief a hard look . DanNaperville wrote: ↑Wed Sep 03, 2025 10:54 amI received mine yesterday. The scales are very stiff, almost zero give in them when grasping the knife to make them deflect.
Very nice knife!
- Naperville
Re: Chief Crucarta
Have not noticed anything shaggy about the grips. Very nice knife, but there are many man other Spyderco Native Chiefs to choose from.
Collect one for every day of the week!!!!
- Brock O Lee
Re: Chief Crucarta
I folded... Incoming...
