M390 vs S90V
M390 vs S90V
Howdy do, again.
I'm looking at the upcoming release of the Native Chief™ Brown G-10 M390 Sprint Run (C244GDBN) next Tuesday.
I already have a Native Chief in S90V that I rarely carry because I love my Native Shaman just too damned much.
I feel like the Shaman is more "sturdy", stronger, whatever, because the blade is taller, it just looks more robust than the Chief.
So I'm wondering if M390 is so superior to S90V that I would feel more comfortable carrying it than the S90V. I know this is a stupid question, I'm probably subconciously asking someone to tell me it IS so I can start justifying spending $250 on a second Native Chief.
I DO like the brown scales better than black, so that's something. I think the slightly bulky "hand-made" looking scales that came on my Shaman would look great on the Chief, but I think I could get by with the stock scales.
Oh, and how would I order one of these knives on Tuesday? From the page that lists the knife as "Coming Soon"?
Oh, and feel free to tell me why I DON'T want one of these knives!
Regards,
FeistyKat
Regards,
FeistyKat
Re: M390 vs S90V
The only advantage M390 has over S90V is corrosion resistance, and S90V is no slouch with about 440C level corrosion resistance. I wish I had gotten one of them Chiefs.
Want: SPY27, K490, Swick 5.
Re: M390 vs S90V
I don't have any experience with Spyderco's M390 but have used M390 from another knife company. And if I were to compare that M390 to Spyderco's S90V (of which I have a bit of experience using at work), I'd take S90V over M390 any day & twice on Sunday.
It keeps a fine edge and a working edge noticeably longer, and I find it more straightforward to sharpen, by which I mean sharpening S90V is just like sharpening S30V, but scaled up in terms of time. You work at it long enough, and you will eventually get a dulled S90V Spyderco back to screaming sharp. With M390, it just seems more temperamental when it comes to sharpening. I've read it described as being "gummy". M390's only advantage is in stain resistance, and even then, unless you're working in an environment where your tools are constantly exposed to corrosive compounds, you won't notice the difference.
Larrin Thomas has a nice table comparing the two (and a host of other steels) at the following link:
https://knifesteelnerds.com/2021/10/19/ ... esistance/
Re: M390 vs S90V
I can't help with the steel choice, because I like both. I'd probably take S90V if I had to choose. But honestly, no steel will make a Chief as sturdy as a Shaman.
Edited to say that I rarely carry my Chief for the same reason: With absolutely no evidence to back this up, it just doesn't look as sturdy as several of my other folders. Most of them, in fact.
Re: M390 vs S90V
If you don't mind the orange scales, there's also a CutleryShoppe exclusive Native Chief in CTS-XHP for significantly less than the upcoming M390 sprint.
XHP is said to have less edge retention than M390, but I like it because I can get XHP sharp with less effort.
https://cutleryshoppe.com/spyderco-c244 ... exclusive/
Re: M390 vs S90V
I have over thought this too in regards to the Chief being too fragile at the tip. The problem is the ergos are just too good, and the lock too amazing, and the carry profile too fantastic not to carry. I don't really think it is a problem. If one were to break the tip, you could always grind it down and get one cool unique looking Chief blade. I love that knife.
As far as the steels, I don't think there is any argument to one over the other minus wear resistance. S90V having the advantage, but not significantly to make a huge difference. You have yourself a really great version of the Chief. I would carry it and enjoy it. I wish they were still around.
Re: M390 vs S90V
My “perfect” (safe queen) Paramilitary 2 when it comes to factory edge( perfect 15dps even cutting bevels), action and f&f is my blue M390 BBS exclusive.It’s a beauty and I love it so much but… I wish it was in S90V. Enough said.
Marius
( Rabindranath Tagore )
BIGSTRETCH
Re: M390 vs S90V
Spyderco does a really good job on both of these steels. M390 will sharpen up to a fine edge more easily and keep it for a long time. You will have a hard time getting as keen of an edge on s90v but it will keep cutting for longer.
If your s90v gets as sharp as you want it to then you are already ahead of the rest in edge retention.
Re: M390 vs S90V
I have an M390 Bradford Gaurdian3 that holds a great edge but is a ***** to sharpen. I also have the Chief in CTS-XHP that I got because it was orange and at a great price ($155 new). Mikey177 is right, even I can get that XHP wicked sharp with no problem. Now I get why the Cutlery Shoppe uses it, it is a great user steel.mikey177 wrote: ↑Tue Oct 11, 2022 6:26 pmIf you don't mind the orange scales, there's also a CutleryShoppe exclusive Native Chief in CTS-XHP for significantly less than the upcoming M390 sprint.
I was going to get the Chief in M390 too as I just love the Chief in pocket and in hand, but, the more I think about it the more I think I want to try that Stretch 2 XL that is coming out in a little bit. Wish it was available in orange g10 but grey could be cool too.
Re: M390 vs S90V
I don’t find spyderco’s m390 gummy at all, I think they do the best job with it of any production company.zuludelta wrote: ↑Tue Oct 11, 2022 6:03 pmI don't have any experience with Spyderco's M390 but have used M390 from another knife company. And if I were to compare that M390 to Spyderco's S90V (of which I have a bit of experience using at work), I'd take S90V over M390 any day & twice on Sunday.
Buuuuut I’m not saying that puts it above s90v.
For what it’s worth, I believe Sal has said S90v is his favorite steel.That carries a lot of weight in my book.
Re: M390 vs S90V
OK, good enough, you've talked me out of the M390!
Thanks for helping me avoid buyer's remorse.
Now I'm looking at that version of the Native Chief!mikey177 wrote: ↑Tue Oct 11, 2022 6:26 pmIf you don't mind the orange scales, there's also a CutleryShoppe exclusive Native Chief in CTS-XHP for significantly less than the upcoming M390 sprint.
That's the only thing I don't like about the Shaman: the lock. I really prefer a back lock on a knife. I think I'm going to start giving my Chief some carry time.JSumm wrote: ↑Tue Oct 11, 2022 7:58 pmI have over thought this too in regards to the Chief being too fragile at the tip. The problem is the ergos are just too good, and the lock too amazing, and the carry profile too fantastic not to carry. I don't really think it is a problem. If one were to break the tip, you could always grind it down and get one cool unique looking Chief blade. I love that knife.
- Naperville
Re: M390 vs S90V
I looked all over and I cannot find anything saying "Tuesday October 18th direct from the SFO" is the release date.
Can you tell me where the announcement is?
What time are they going to be available Tuesday October 18th direct from SFO? Anyone know?
I hope these don't sell out fast... I'll never get one.
- Naperville
Re: M390 vs S90V
I see the announcement now. Not sure how I missed it.Buddafucco wrote: ↑Tue Oct 11, 2022 9:59 amTwo new Native Chief Sprint Run models will be available on Tuesday October 18th at 9am MDT factory direct from Spyderco. Limit 1 each per household.
Thank you!
I like the design so I'm trying to snag one of each.
If Spyderco made an Native Chief XL, I'd have to have it! Maybe someday!
Re: M390 vs S90V
I wouldn’t worry about the strength of the Chief. I will concede that I believe my Shaman is a stronger overall knife, I have no reservations using my Chiefs hard though. I have two in two different steels and use them harder than most I would say. I’ve even dropped them both on concrete off of ladders multiple times and haven’t broken a tip off yet. I’ve probably jinxed myself now though.
I like both steels, to your original question though. I think you’d be happy with either.
Slightly obsessed…
Re: M390 vs S90V
If it comes to the steel I would pick S90V over M390 anytime. If it's about sturdy, beat up knife Shaman is way better in any steel. But then again it depends where you live and what you do with your knife. If rust and pitting is a concern, M390 is excellent choice. On the other hand the Native Chief doesn't look like a beat up knife, but the long blade with the pointy tip is very useful in a lot of scenarios. For me it's a scalpel on steroids. Everytime I have a tiny splinter under my skin the Native Chief is there to save the day.
- Brock O Lee
Re: M390 vs S90V
The S90V CF model is in my view superior and more desirable than the M390 G10 model. You love the Shaman, and you already have a nice Chief, so why not get a Shaman in another material combo instead?
Re: M390 vs S90V
Both are fantastic steels, and honestly unless you are a really keen sharpener you probably won’t tell much of a difference. Spyderco does a fantastic job with both, so pick your scale of choice!
The Wife photo bomb!
Dane
Re: M390 vs S90V
I'd side with s90v, but m390 is great as well. But my s90v chief is one of my favorite knives to carry. Now if I had an s90v/cf shaman to go with it... Mmmm
Re: M390 vs S90V
I bought some m390-family of steel early and loved it, but it seemed to always want to chip a little if I got to aggressive or just grazed something hard. That's when I realized that I wanted to avoid that characteristic and moved to favoring toughness over stain resistance.
I only have one s90V and I haven't used it too hard, but I have liked it so far. It seems to be run at a higher hardness than the m390/204p. This makes s90v feel different on the sharpmaker. m390 always felt buttery on the sharpmaker, whereas s90v feels quite a bit *cannot think of a word to describe it* harder. It makes a different sound that is recognizable as being a higher hardness after you use the sharpmaker for years...
Both are great, but I've moved from m390-family, back to some m4, rex45, and others. s90v seems to be a great option for a long wearing very stain resistant steel.
I'm looking forward to the sprint Siren in s90v.
Re: M390 vs S90V
Yeaaaa, the S90V Chief is one that whenever I see it, it tempts me. But, I try to be logical that I already have it in Rex45 and M4...and have the holy grail S90V Military. Every time I see that Chief though... One of these nights, after a couple too many drinks...I'll probably end up with one in my mailbox a few days later
