Para Military 2 Salt DLC Review: High-utility, low-maintenance
At this point in time, a Para Military 2 review might seem a bit unnecessary. The original Para Military folder designed by Sal Glesser was introduced in 2004 and the current generation Para Military 2 (which I’ll refer to as the PM2 from this point forward) designed by Sal and Eric Glesser has been around since 2012. As with the even older Delica and Endura models, the Para Military design has been around for so long that just about everyone who is into knives has already decided that they either love it, hate it, or they are indifferent to it. But there are always new people coming into the knife community—so new that they haven’t yet had the opportunity to handle a PM2—and it is primarily for them that I am writing this review.
I first acquired a PM2 way back in 2017, a blacked-out DLC model in S30V. I had, of course, read the many online complaints about the PM2’s supposedly fragile tip and I did end up damaging the tip of my first PM2 eventually when I accidentally dropped it tip first onto a concrete floor from a height of about 5 feet, but that was a drop that would have damaged the tip of just about any knife. It took less than an hour for me to fashion a new tip with just a file and a very coarse diamond plate, no big deal. I liked (and still like and use) that first PM2. It wasn’t as efficient of a slicer as my main work folder (the hollow-ground Yojimbo 2), but it still cut very well due to the height of the blade giving the PM2’s full flat grind enough room to come down to a relatively acute angle. I also love the PM2’s blade shape: the pairing of the low tip and the gradual, continuous curve to the edge has it performing almost like a Wharncliffe on most utility cutting tasks, but it still has enough of a belly that cutting against a flat surface is no problem. I wasn’t too thrilled with the PM2’s feel in hand at first—to me it felt almost like a much boxier Endura 4—but it grew on me over time and I also came to appreciate the extra gripping area for choking up provided by the forward finger choil. The action on that first PM2 was also rather good, despite being from an earlier production run before the CQI change that introduced the pivot bushing system found in all current-production PM2s. Over time, I’ve managed to pick up a few more PM2s as a platform to try out different steels such as S110V, Cru-Wear, S45VN, 15V, and MagnaCut. I think one of the reasons why the PM2 is so popular is because of how many “flavours” it comes in. Currently, the Para Military’s Spydiewiki page lists the PM2 as having been produced in 22 different steels across regular production runs, Sprint runs, dealer exclusives, distributor exclusives, and very limited special editions. That is a mind-boggling number before one even takes into account the different variations in handle materials, blade finish/coating/cladding, and more radical departures like tanto and Wharncliffe blade shape models, models with integral Emerson Wave openers, and models with custom laser-engraved blades.
Through years of regular work use and across multiple variants, I have found the PM2 to be a very effective, utilitarian design, even though its very prominent “Spydie-hump” isn’t something I’m overly fond of (because of how I like to grip a knife, I generally prefer Spydercos with low-profile or non-existent thumb ramps like the Yojimbo 2, Lil’ Temperance 3, Caribbean, and Shaman). Still, the PM2 is among the handful of knives that I would be perfectly happy with if they were the only folder I could use for the rest of my life.
This brings us to my experience with the PM2 Salt DLC in MagnaCut. I spend a fair amount of my free time outside of work helping maintain the many local public forested areas (what the city officially refers to as “Urban Forests”). The city does employ workers who are tasked with clearing deadfall and fallen trees after storms and planting trees and shrubs to maintain forest cover, but volunteers are always needed to help with this work and many times, the job of clearing deadfall and fallen trees on forest trails is put on the back burner because the priority is clearing them from populated areas. When volunteering for this type of work, I have always carried a small-fixed blade like the Street Beat, a Ronin 2, or even a Swick 6 for small outdoors knife tasks, not because I need the added robustness of a fixed-blade—many modern Compression Lock and CBBL folders are plenty strong for small outdoors knife work—but because the work can get very dirty and wet, especially in the fall months. Anyone who has ever used a folding knife for a long time in the mud and dirt and had to clean it afterwards knows what an absolute pain it can be to have to take it apart, not just to ensure that all the parts that are susceptible to rust can be dried, but also to get all the grit out from the nooks and crannies and get the knife operating smoothly again.
For the longest time, this kind of activity was my primary use case for a small fixed-blade. Last year, however, I started bringing the PM2 Salt with me to the forest instead of the Ronin 2, Street Beat, or Swick 6. There are advantages to using a folder for small outdoors knife work, chief among them is that I can just carry it in my pocket, instead of having to deal with a sheath clipped to my belt or waistband. Sheaths (and the knives they hold) can catch on all sorts of stuff when maneuvering through dense growth and crawling under/clambering over fallen trees, and they can poke you in the side or on the belly when having to do all sorts of contortions to get into inaccessible spots. There is also the familiarity factor: I’ve already built up muscle memory for deploying, using, and pocketing a folder from using one for years at work. Sure, pulling a fixed-blade out of its sheath is faster than deploying a folder from the pocket, but at least in my case, closing and safely pocketing a folder is faster than safely resheathing a small fixed-blade (have you ever pricked yourself in the side or on the hip with a knife while hastily resheathing it? I don’t recommend it, AT ALL). On a recent woody shrub planting session to help with soil-stabilization in sloped areas, I used the PM2 Salt to cut through roots I encountered while digging planting holes. The rain was coming down really hard during this time so I was working in the mud, with very muddy gloves. While I think a PM2 with regular G10 handles wouldn’t have been too slick to use in these conditions, I appreciated how much traction I could get on the PM2 Salt because of the ribbed, Caribbean-style texture pattern on its scales. And even though I was wearing gloves absolutely slathered in muck, I did not have any issues accessing the Compression Lock cutout. When I had finished with the planting, I simply walked over to a nearby lake and dunked the PM2 Salt in the water a few times to get rid of the worst of the mud and grit, just like I would have done with a fixed-blade. And when I got home, I was able to get rid of the rest of it with some well-placed bursts from the kitchen sink sprayer and a few minutes of scrubbing with an old toothbrush and plain dishwashing liquid. To me, it is this ease of cleaning and maintenance that really sets apart the PM2 Salt (and really, all of Spyderco’s Salt folders) from many of the MagnaCut or LC200N-bladed folders made by other companies, and what makes it a truly viable small fixed-blade replacement. When I clean out the PM2 Salt or any of my other Spyderco Salt folders after a day of using it in a wet and muddy environment, I can rest assured that the entire knife, and not just the blade, is optimized to resist corrosion. Had I used one of my other non-Spyderco Salt MagnaCut folders, I would have had to take it apart for cleaning anyway because there is always the chance that the hardware and liners would rust from retained moisture. It is for these reasons that I highly recommend the PM2 Salt (or really, just about any Spyderco Salt folder that fits one’s budget) for anyone who spends time working in or just enjoying the outdoors.
Re: Para Military 2 Salt DLC Review: High-utility, low-maintenance
Nice writeup, Zulu! I really enjoy your reviews.
I was on the fence about this one, but then the Military 2 Salt debuted and I decided to give it a try instead. It's probably the folder I'd choose if I absolutely had to pick just one (Stretch 2XL Salt and Pacific Salt are right there with it) but, if it didn't exist, the PM2 Salt might fill its place. Often, when I pick up a different ilk of Salt, I find myself wishing for the textured G10 the PM2 Salt and M2 Salt share.
Great review, zuludelta!
How abrasive is the texture of the scales under the clip's contact point on the pocket material?
I haven't had any issues with the Military in that respect, and I expected to.
This knife has wound up being the one Spyderco I carry the most, despite not really liking it after it first came out. Generally I prefer wharncliffe blades, back locks, aluminum or micarta scales, and no coating, so this basically had nothing going for it. I think it just became a case of it not having any of the issues or downsides of the other knives in my collection; it needs almost no maintenance, you can use it pretty thoughtlessly other than not being a moron with the tip, you could sharpen it like 100 times and the tip would not even come close to protruding from the scales, and the ergonomics are completely flawless.
Another great and real life review!
I personally do like the PM2 platform, but in that size range Stretch 1 or 2 and Endela are better options for me for several reasons. But those of course can´t be had as "Salts" if one needs that high level of corrosion resistance.
Two questions, if I may:
- Wouldn´t the Caribbean be an even better "Salt" option for you in that size range, especially since you like more subtle thumb ramps? (And the plus of cutting edge perhaps would not hurt either?) Or is it that you want Magnacut and not LC200N?
- And did you ever try serrations (preferably in H1/H2) for the kind of work you describe?
I find my H1 Pac Salt SE clearly superior to PE when it comes to cutting off smaller branches and generally working with wood in a more "rough" manner (so NOT detailled work) - rips way better through for example the tough branches of dwarf mountain pines and stays sharp or at least "able to separate stuff" a lot longer....
Thank you for reading! I plan on getting a Military 2 Salt eventually as my first Military 2, but they've been sold out across Canada for a while now. I might just wait for the non-DLC coated version to come out.Coastal wrote: ↑Thu Nov 06, 2025 6:27 pmNice writeup, Zulu! I really enjoy your reviews.
As vivi noted, the modified Caribbean texture used on the PM2/M2 Salt DLC handle scales isn't especially more abrasive than what you'd expect from the typical finish on G10 handle scales from Spyderco or even from an FRN-handled Spyderco with the bi-directional pattern, but the added texture really does make a difference when gripping the knife in wet conditions.
What sets the texture of the PM2 Salt handle scales apart from the Caribbean handle scales is that the former have the pattern reverse-etched into the G10, so the ribbing isn't actually raised above the scale. The Caribbean handle scales, on the other hand, have the texture pattern conventionally etched, so the ribbing is raised above the main body of the scale. So even though the Caribbean scales have a smooth finish, I find that they are actually more damaging to a pocket hem because the edges and corners of the raised ribs rub against the fabric.
This pretty much sums up how I feel about the PM2 Salt, at least in an outdoors use context. There are folders which I like more for various (sometimes subjective) reasons, but when it comes down to just having a no-nonsense folder that I know will work in adverse conditions without having to spend an inordinate amount of time on maintenance afterwards, it is the one I reach for the most often.Wallach wrote: ↑Thu Nov 06, 2025 9:09 pmThis knife has wound up being the one Spyderco I carry the most, despite not really liking it after it first came out. Generally I prefer wharncliffe blades, back locks, aluminum or micarta scales, and no coating, so this basically had nothing going for it. I think it just became a case of it not having any of the issues or downsides of the other knives in my collection; it needs almost no maintenance, you can use it pretty thoughtlessly other than not being a moron with the tip, you could sharpen it like 100 times and the tip would not even come close to protruding from the scales, and the ergonomics are completely flawless.
You nailed it on the Caribbean and why (for now) I'm going primarily with the PM2 Salt for my outdoors work folder. I like the Caribbean (it's basically a longer Lil' Temperance 3, and I think everyone here knows how much I love that knife) but the MagnaCut blade just edges the PM2 Salt over the Caribbean for me. Significantly more wear resistance/edge retention, a barely measurable downgrade in corrosion resistance (and the DLC coating on the PM2 Salt probably closes the gap between the two), and almost just as tough.
Also, as I mentioned in my reply to James Y and vivi above, there are subtle differences between the handle texture of the Caribbean and the PM2 Salt that make me prefer the latter. The protruding corners of the ribbing on the Caribbean handle really wears on pocket hems after a while, and they also start to feel a tad uncomfortable after a few hours of working with wet hands.
An updated Caribbean with a MagnaCut blade and the newer texture used on the Golden G10 Salts would be very close to the ideal outdoors work folder for me, though. The upcoming MicroJimbo Salt and Shaman Salt would come very close to the ideal as well, but you know me, a (hypothetical) Yojimbo 2 Salt in MagnaCut would probably be the last folder I would ever buy! (who am I kidding, I'd probably find an excuse to buy a new Spyderco every now and then even if I have my dream folder)
I have used serrated LC200N and H1 for forest maintenance work, and yes, they do work quite well. I only have those serrated steels in mid-backlocks though (a Salt 2 for serrated LC200N, a Dragonfly 2 Salt for serrated H1), and for really dirty and gritty work, I prefer a knife with an open-back, flow-through design such as the PM2 Salt. It just makes for easier cleaning afterwards.- And did you ever try serrations (preferably in H1/H2) for the kind of work you describe?
I just spent a week playing in salt water with my Chief Salt and it doesn't have a spec or corrosion on it. We even spent the better part of a whole day snorkeling and it was on my hip IWB the whole time. MagnaCut may not be literally as rust proof as H1/H2/LC200N but geez I'm not sure what more I could get myself into to make it rust. The best part about steels like this is the edge was still plenty sharp by the end of vacation and wasn't lost to corrosion, can't say the same for a lot of other steels.
Many thanks, vivi!
zuludelta wrote: ↑Fri Nov 07, 2025 5:45 amAs vivi noted, the modified Caribbean texture used on the PM2/M2 Salt DLC handle scales isn't especially more abrasive than what you'd expect from the typical finish on G10 handle scales from Spyderco or even from an FRN-handled Spyderco with the bi-directional pattern, but the added texture really does make a difference when gripping the knife in wet conditions.
Thanks a lot for the explanation, zuludelta! I hadn't considered or known that the ribbing on the scales of the PM2 Salt are into the G10, while the Caribbean's (one of which I do own) ribbing is raised above the scales.
Red Leader
Don’t have the black DLC, edition, but my bumblebee PM2 salt (on me now) is fantastic and I will respectfully disagree with Seth from Knife Center who sees the PM2 as a red headed stepchild, I see it as the goldilocks. Different mindsets.
navin johnson
I found the P2 lock bar would not close when debris wedged between the lock bar and the scale while doing mud/dirt work. And would sometimes require tools to close the knife.
I enjoy Seth's content on the KC channel and his own channel, but I do find it odd that he would say that, given the PM2's seeming popularity with all the variants that have been released. I have to assume that he meant it in the sense that it's a somewhat polarising design, because I do think it is. I think as Spyderco users, we're all just so used to its appearance, but it probably looks at least a little weird and unusual to "non-knife people" or people who don't really know about Spyderco.Red Leader wrote: ↑Fri Nov 07, 2025 10:58 amDon’t have the black DLC, edition, but my bumblebee PM2 salt (on me now) is fantastic and I will respectfully disagree with Seth from Knife Center who sees the PM2 as a red headed stepchild, I see it as the goldilocks. Different mindsets.
I guess I have been fortunate in that I've been able to shake/knock loose or rinse out any debris that has wedged between the lockbar and the scale in the times I've used the PM2 Salt in muddy conditions. But yes, something like what you describe can still happen with any folding knife that is used in muddy and gritty environments. Still, I have found debris interfering with the knife's operation less of an issue with the PM2 Salt because of its flow-through construction compared to my mid-backlock Salts.navin johnson wrote: ↑Fri Nov 07, 2025 11:00 amI found the P2 lock bar would not close when debris wedged between the lock bar and the scale while doing mud/dirt work. And would sometimes require tools to close the knife.
I'll be honest, all the online MagnaCut hype was getting to be a bit too much for me after a while. No fault of Larrin, of course, just all the knife company marketing and influencer noise on social media going into overdrive. But it can't be denied that it's absolutely lived up to its billing, truly amazing stuff.Evil D wrote: ↑Fri Nov 07, 2025 7:29 amI just spent a week playing in salt water with my Chief Salt and it doesn't have a spec or corrosion on it. We even spent the better part of a whole day snorkeling and it was on my hip IWB the whole time. MagnaCut may not be literally as rust proof as H1/H2/LC200N but geez I'm not sure what more I could get myself into to make it rust. The best part about steels like this is the edge was still plenty sharp by the end of vacation and wasn't lost to corrosion, can't say the same for a lot of other steels.
This pretty much answers the question I was about to post:zuludelta wrote: ↑Fri Nov 07, 2025 12:13 pm....
As much as I am a backlock guy, in rare, extreme conditions snow or also rather dense mud can clogg up the lock inferface and prevent the backlock from properly closing.
I was wondering if this is also a thing with comp.locks, since my experience with this locktype is limited compared to backlocks, especially in such extreme conditions.
Now it sounds like this CAN be a thing indeed also with comp.locks, but to a lesser degree than it is the case with backlocks.
Red Leader
It would be really fun to sit down with Seth and have some of these discussions. I know he is a CRK guy, and my very first experience with CRK a few months ago, handling about 5-8 models was neutral-to-slightly disappointing. They sort of felt ‘sluggish’ - but I know they improve with use and not everything does, which is admirable. We are blessed with so many choices these days.zuludelta wrote: ↑Fri Nov 07, 2025 12:13 pmRed Leader wrote: ↑Fri Nov 07, 2025 10:58 amDon’t have the black DLC, edition, but my bumblebee PM2 salt (on me now) is fantastic and I will respectfully disagree with Seth from Knife Center who sees the PM2 as a red headed stepchild, I see it as the goldilocks. Different mindsets.
The fact that it requires very little maintenance is truly an impressive advantage.
I also appreciate this aspect, which is why I often use the Salt series even in non-marine environments.
The scales with excellent grip are also very practical. The PM2 Salt is the most advanced factory knife I’ve ever handled.
And thanks to MagnaCut’s characteristic toughness, I’m hoping—just a little—that the previously fragile tip has been somewhat reinforced...
