You must have the magic touch... I ordered mine within 15 minutes of release and it hasn't shipped just yet.
KnifeCenter CPM-CRUWEAR Native 5 with smooth black G10
Re: KnifeCenter CPM-CRUWEAR Native 5 with smooth black G10
tbdoc4kids
- curlyhairedboy
So I did some hardness testing on the manix version, and the Cruwear tested at 62.6 HRC. :D
ergonomics are so good on this model, I feel it is perfectly fine to use smooth G10 scales.
Pickmansmodel82
Hemmed and hawed a bit on this one, but pulled the trigger on it. The native is my 2nd most carried model, and the design ergos are good enough I don’t mind the smooth G10
- The Mastiff
They have their heat treats dialed in and very consistent. If you get around to testing a Japan made one please post your test results.So I did some hardness testing on the manix version, and the Cruwear tested at 62.6 HRC.
I have tried CPM Cruwear from around rc 59 up to rc 64.5 in a custom and I have yet to find a heat treat for this steel more suited to my needs than Spyderco's. They did their homework on it.
Joe
bagsnatcher
Looks great! Thanks for the pic. :Dbagsnatcher wrote: ↑Mon Aug 05, 2019 2:37 pmHere it is. It's absolutely perfect.
And if you're hesitant about the smooth G10, stop. It's absolutely wonderful, and it doesn't tear up my pants.
I received notice at around noon today that mine shipped. :)
I've only tried smooth G10 on the PM2 from KC and I didn't like it at all. I think that the smooth G10 would be fine for a Native though. Only reason I haven't ordered one yet is because I just picked up a CRUWEAR Delica.
bagsnatcher
BTW,
KnifeCenter has the Delica in Cru-Wear up. It went up 3 minutes ago.
bagsnatcher
I can see it being a problem in a large(er) folder, maybe.
But in something like the Native, in an office environment, and/or light EDC, this thing is absolutely phenomenal. It makes perfect sense.
I went ahead and grabbed one. I have a set of blurple scales that are sanded a bit for easy in/out of the pocket. It currently has M4 in it but may do a blade swap and sell the M4.
bagsnatcher
I think you're safe, regardless. Worst case scenario, you might be out a few bucks (cost of "renting" the knife) after flipping it on the secondary market.
bagsnatcher
Here's one more, and I'm done for the day:
You guys make me trust no one on the secondary market. That's cool.
I've had excellent luck with eBay. I buy from normal people (not iffy seeming distributors) that have 100% feedback.
bagsnatcher
Reddit knife swap, JerzeeDevil, and BladeForums (probably in that order).
I've transacted probably 15K USD year to date through these venues.
To be clear, I'm not advocating swapping out blades, and then passing the knife along as an original. I've seen plenty of blade swaps / handle swaps for sale, and they have all been properly advertised as such.
I like deals, I deal on the secondary market all of the time. Reckon I don't trust you.
