BBB has done a great job making posts showing just how much influence edge geometry has on edge retention. Basic idea being the thinner the edge, the higher the edge retention, until catastrophic failure is reached.
This is common knowledge now.
The idea has been pushed since before I got into high end knives 20-25 years ago,but mainstream acceptance of the idea how grown much since those days.
Back in the early to mid 2000's on knife forums it was often said, incorrectly, thicker edges have better edge retention.
Now we have a wealth of data from catra tests and other controlled cutting demonstrations showing the opposite is true.
BUT.
The majority of people still run factory edges on their knives.
I'm not talking about average folks that may not even carry a pocket knife, and if they do it's a $5 knife from a gas station.
I'm talking about people dropping $200-600 on 15V and other exotic steels.
I don't get the point of chasing such high performance but then being unwilling to go thinner than about 20-17 degrees per side.
An analogy I've used a lot is to me it's like buying a nice sports car but then keeping the tires at 25PSI and using basic unleaded gas.
It's leaving performance on the table after going out of your way to purchase a performance oriented piece of gear.
Some of my earliest posts here were about this subject. Here's a thread from 2008 I made about taking my UKPK down to a full convex reprofile, under 10dps at the edge - viewtopic.php?p=436487#p436487
Been beating this drum for years but it seems like it still isn't catching on.
It's something I think about often when I'm talking about steels, edge retention etc. here.
Someone sharpening their factory edged S30V knife on a sharpmaker using the 20 degree slots could honestly being getting only 50% of the edge retention I get from my S30V Military 2 sharpened to about 12 degrees per side.
That's a big,big difference.
Deadboxhero / BBB has tons of posts on the subject. viewtopic.php?p=1819892#p1819892
So S30V, a steel a lot of folks here and elsewhere scoff at, will actually out cut a lot of more modern super steels due to how I sharpen it.
This is just talking about pure edge retention. I haven't even touched on how my reprofiled knives will take less effort to cut the same material, or will be more ergonomic to use for certain tasks because I don't have to tilt my wrist as much (carving wood with a 20dps edge vs 10dps feels much different).
Feels strange seeing so many maxamet, 15V, 20CV, M390, S110V etc. knives run thicker than a 420HC Buck 110.....and their owners being perfectly fine leaving them that way.
Anyone here that wants a good example of "geometry cuts" should order themselves a Kiwi 172. It's a $5 kitchen knife using bottom of the barrel mystery stainless, but boy does it cut.
