Detent tuning
Sjucaveman
Detent tuning
Post by Sjucaveman »
I was very nervous to tune my first detent on a spyderco knife but decided it was that or sell a couple knives I found the detent too weak on. I took apart my sliverax and got out the dremel with a small round diamond bit. I turned the dremel to 5k rpm and went slowly. After deciding it looked sufficient I put it back together and it's FANTASTIC! Super excited to give new life to spydies that aren't being carried.
Adam
Mstach07
Re: Detent tuning
Post by Mstach07 »
Sounds interesting. What exactly were you trying to tune or tune-out?
Sjucaveman
Re: Detent tuning
The detent was too weak to flip well. I have the same issue with my carribean and lum tanto though they're not flippers.
Adam
mb1
Re: Detent tuning
Post by mb1 »
I think that’s pretty cool. I assume you made the detent divot (or whatever it’s called) deeper. Any way to make a strong detent weaker?
- Mark
Re: Detent tuning
I did the same to mine a couple months ago. It worked like a charm!
Pelagic
Re: Detent tuning
Post by Pelagic »
So vague, lol. Any pictures?
Pancake wrote:
Wed Aug 14, 2019 10:20 pm
Are you a magician? :eek:
Nate wrote:
Thu Apr 04, 2019 4:32 pm
Doeswhateveraspidercan wrote:
Sat Jun 15, 2019 9:17 pm
You are a nobody got it?
Tims
Re: Detent tuning
Post by Tims »
The only tuning I’ve done to achieve a stronger detent is by bending the lockbar in to increase the pressure it has on the blade in the closed position.
To weaken the detent you would do the opposite. Bend it out.
Both done with knife disassembled.
I can’t visualise what you could have done with a dremel other than grind a detent ramp on the blade but that won’t increase detent strength?
Liquid Cobra
Re: Detent tuning
Post by Liquid Cobra »
Now that I have a dremel I’ll really need to try this on my sliverax and amalgam.
@liquid_cobra
500Nitro
Re: Detent tuning
Post by 500Nitro »
Photos would be good of these variations - for the non technically minded !
zhyla
Re: Detent tuning
Post by zhyla »
500Nitro wrote:
Sat Dec 29, 2018 6:16 pm
Or for the technically minded too. What are we taking about? Deepening the detente hole? With a dremel??
Re: Detent tuning
This is what I used to open detent hole. I could've used a rotary tool but I chose to turn the bit by hand. I took a little off at a time and tested until it was where I wanted it. I'm very happy with the results.
ABX2011
Re: Detent tuning
Post by ABX2011 »
Seems risky. Remove too much and you could end up with detent play.
Re: Detent tuning
ABX2011 wrote:
Sat Dec 29, 2018 6:37 pm
Yep! That's why I took my time and did it by hand. I dislike detent slop, so I was careful not to go too far.
Tims
Re: Detent tuning
Post by Tims »
Sharp Guy wrote:
Sat Dec 29, 2018 6:27 pm
Did you do this because the hole was too small and the detent ball wasn’t fully seating?
Re: Detent tuning
Tims wrote:
Sat Dec 29, 2018 6:46 pm
Yes, the detent was a little on the light side, so I opened the hole a tiny bit to make the ball sit a little deeper.
brainfriction
Re: Detent tuning
Post by brainfriction »
mb1 wrote:
Sat Dec 29, 2018 5:04 pm
Yeah I'd be curious about that too. I know on frame locks you can just bend the lock bar out a little, some people do that with the Domino but it might be a little trickier to get just right with a comp lock.
Tims
Re: Detent tuning
Post by Tims »
brainfriction wrote:
Sat Dec 29, 2018 7:09 pm
The comp’ lock is just like a linerlock in the way it acts on the blade. To weaken it just pull the knife down, separare thr liner with lock bar from the scale and bend the lock bar out so it exerts less pressure on the blade. With less lock bar pressure the ball will pop out with less force when you open the knife.
curlyhairedboy
Re: Detent tuning
Post by curlyhairedboy »
I've done this a number of times. Always by hand, as it's easy to remove metal and hard to put it back. Definitely helps the Taichung models. I find the Golden spydies have stronger detents from the factory.
razorsharp
Re: Detent tuning
Post by razorsharp »
A mod I have performed a lot of times :) I prefer to use a small cylindrical bit as you can keep the edges of the hole closer to 90 degrees :)
shunsui
Re: Detent tuning
Post by shunsui »
