Sharpmaker and S35VN?
Robert Ptacek
Post by Robert Ptacek »
I am getting a lot of conflicting data on whether the Sharpmaker can handle S35VN.I plan to reprofile knife to a lower angle on a benchstone and then finish with the Sharpmaker.Is it up to the task as some say only diamonds are good enough?What say you-yea or nay?
illacky
Re: Sharpmaker and S35VN?
Post by illacky »
Sharpmaker will work fine, however you may want to pickup the CBN or diamond rods for it for reprofiling.
-Ivan
Sjucaveman
Post by Sjucaveman »
It can certainly handle s35vn.
Adam
Yep! I use the SM for S30V-S35VN all the time. Works well for me!
legOFwhat?
Post by legOFwhat? »
Is there any blade steel that Spyderco produces that the SharpMaker is not good on?
-Larry
MNOSD #0049
kadinh
Post by kadinh »
I sharpen my S110V PM2 on my sharpmaker just fine.....
Sharpmaker can technically handle any steel, the question is if you have the time and patience that some steels will demand.
Robert Ptacek
I want to clarify I will grind the knife to a thinner edge on a coarse benchstone until I get a bur and then proceed to a final edge on the Sharpmaker.I wouldn't try to reprofile any knife on the Sharpmaker .I feel it's niche is as a final step in edging or as a light touchup.
bearfacedkiller
Post by bearfacedkiller »
You are good to go then. I often reprofile on a bench stone and then debur and microbevel with the sharpmaker. That is where is shines. I have used it to do just that with S110V, S90V and Maxamet so S35VN will be no problem.
Robert Ptacek
Thanks for all of your quick responses.This helps alot.
Fixmeister
Post by Fixmeister »
I have knives in S30V, S110V, CPM 20CV, ZDP-189 and M4 (and soon... REX 45). It handles them all. I use a Wicked Edge for all serious sharpening and the Sharpmaker for touch ups once they lose their stupid sharpness. There are ultra fine stones for the Sharpmaker too. I have them and use them as well.
zhyla
Post by zhyla »
Robert Ptacek wrote:
Wed Aug 15, 2018 12:39 pm
Are you sure you want to do that free hand? I've only reprofiled one knife but it's hard to get a perfectly consistent bevel even with some kind of sharpening guide system.
Robert Ptacek
zhyla wrote:
Wed Aug 15, 2018 3:53 pm
I've done it that way for years.Reprofile on coarse stone and final edge on the Sharpmaker.I've heard so many stories on it can't be done without diamonds.
Bloke
Post by Bloke »
Thu Aug 16, 2018 2:00 am
They likely are indeed stories.
For what it’s worth I reprofile/sharpen everything S110V included with SiC and maintain with SharpMaker. :)
Robert Ptacek
Bloke wrote:
Thu Aug 16, 2018 5:23 am
Very good.Thank you
Woodpuppy
Post by Woodpuppy »
Evil D wrote:
Wed Aug 15, 2018 12:32 pm
^^ this! A man’s got to know his limitations.
