Para 3 exclusive at River's Edge Cutlery
Just happened upon this, anyone else hear about it yet?
https://riversedgecutlery.com/rec-exclusive-para-3
				The Meat man
Re: Para 3 exclusive at River's Edge Cutlery
Not me. It has definitely piqued my interest though!
I wonder what blade steel it'll have?
- Connor
				Liquid Cobra
PVD eh? I’m intrigued.
@liquid_cobra
@liquid_cobra
				koenigsegg
Think they would color the blade? PVD on certain lights i've seen lets them color things.  Isn't this the process they use for DLC coating as well?
I guess this is how they are coating the back lock of the gold Delica and Endura as well
S30V, VG10, M4, XHP,  BD1, Cruwear, Elmax, Maxamet, 204P, H1, K390, A11, Rex45, LC200N, M390, 20CV, BD1N, S45VN waiting to afford MagnaCut
						- Spydersense
Had not heard about it before now.  Definitely interested.
									Time for another :spyder:!
-Matt
						-Matt
- Deadboxhero
Physical Vapor despostion (PVD) is the process
DLC ( Diamond Like Carbon) "Black" is one of the many coatings that uses PVD.
We'll have to see what the choose, maybe a different color then black.
				Username827
Been looking for an excuse to pick up a para 3. Maybe some micarta scales, hmmm. Oh boy
Intriguing! I wonder what the steel choice is.
This is probably part of the long line of dealer exclusives of the para 3 to come.
What do we have confirmed so far? the M390 bbs, BHQ M4, Rivers Edge, and ...?
-Ivan
interesting
well... i'll have to get this one too I guess...
What does PVD stand for?
Yes, I emailed Brian Kent the general manager and got back to me saying he would add me to the list to be notified when they drop. He also the specs on the knife would be released soon.  :)
						- WireEdge Roger
Pretty cool!  River’s Edge is one of the few shops I’ve actually visited.  I’ll have to budget for this one, I’m sure it’ll be top notch.
Physical vapor deposition.
Normally it's a metal-ceramic coating on the order of some thousandths of an inch thick applied in a vacuum to a metallic surface. It's a process to increase the lifetime of drill bits and endmills, as well as other metal things that benefit from a very hard coating.
Another method of applying such coatings is chemical vapor deposition (CVD)
Have:  old S30V Native, HAP40 Endura, ZDP DF2, S110V Manix LW, Cru-wear Para 3, SE H1 DF2, S90V Native 5, K390 Urban, SE Pac Salt, P.I.T.S., XHP Manix LW, SB Caly 3, B70P, PMA11, K03, Kapara, REX 45 Military, 154CM Manix LW, Swick, AEB-L Urban, KC Cruwear Manix, M390 PM2, Mantra 2, CruCarta Shaman, M390 Manix, K390 Police 4, S90V Manix LW, Rex 45 Manix LW, 20CV Manix, Rex 45 Lil’Native, Shaman, C208GP, Cruwear Manix, Cruwear  Manix, M4 Chief, Z-max!!!
Want: SPY27, K490, Swick 5.
Does it bond (chemically) with the metal? And if so (I'm assuming it would bond with some much more well than with others), which ones does it bond with best?attila wrote: ↑Sun Jun 24, 2018 4:26 pmPhysical vapor deposition.
If anyone knows.
That's a beyond my limited knowledge of the process. I don't know the precise bonding mechanism. Also, because there are countless combinations of materials that can be used as PVD coatings, and most metals can be coated, I can't answer which has the strongest bond. There's really no way to answer that.Pelagic wrote: ↑Sun Jun 24, 2018 4:32 pmDoes it bond (chemically) with the metal? And if so (I'm assuming it would bond with some much more well than with others), which ones does it bond with best?attila wrote: ↑Sun Jun 24, 2018 4:26 pmPhysical vapor deposition.
If anyone knows.
As I understand it, however, the deposited material remains chemically distinct from the substrate (steel) that it's applied to.
A properly-applied PVD coating will stick to its substrate as if it were the same material and is not likely to be removed by any mechanism besides abrasive or adhesive wear. As wear occurs, the PVD coating will lighten and fade, until the substrate is exposed. That should take a long time in regular knife cutting applications, but I've not tested it, and I don't know what material they are applying via PVD. It also depends on what you're cutting.
This looks very interesting.
I hope it's the glossy black PVD.  That's an amazing look.
I hope it's not S90V.. seems to be what a ton of exclusives are..
Yeah. Time for more variety.
