Sal, why is the Delica ground so thick behind the edge ?
elena86
Post by elena86 »
Slightly thicker than the PM2 according to my measurements( both sharpened at 15dps). It's a nonsense and a waste of slicing capabilities for the Delica's 2,5 mm blade IMHO. :confused:
Marius
( Rabindranath Tagore )
razorsharp
Re: Sal, why is the Delica grinded so thick behind the edge ?
Post by razorsharp »
Hence why my delica ended up on a grinder way back when before I gave it away :p
Daveho
Post by Daveho »
Never had any trouble cutting with one.
Are you actually running into problems?
Larrin
Post by Larrin »
Poor Sal has to answer for everything.
JonLeBlanc
Post by JonLeBlanc »
Larrin wrote:
Mon May 28, 2018 6:17 am
I know right
ABX2011
Post by ABX2011 »
Try measuring further up and then compare to the PM2.
These are production knives that are inherently compromised to perform well for the average user. If you need a knife more optimized for slicing then modify the knife or buy something else.
Nate
Post by Nate »
Sal recently addressed a simiar question on Cliff's forum, hopefully he doesn't mind the cross-quoting:
"First, when we select a geometry for a blade in production, we really can't make the optimal geometry for a particular steel because all of the customers are different. We have to select an optimal for the majority of the customers.
second, we assume that guys like you or me can adjust the geometry more specific to the material..."
(From: Can Geometry Make Up For Wear Resistance?)
I'd assume that's the majority of the answer, it's a mass-market design for the average Joe. Then probably some variation around whatever the target is in production.
:spyder:
Because we live in a world where the measure of a good knife is how well it can be used for non knife jobs. If Spyderco made everything like the Nilakka they'd get branded as a fragile knife company that can't survive "real world use".
elena86
Post by elena86 »
You're missing the point here. I'm just saying that there is no reason to have a 2.5 mm blade stock and grind it thicker than a 3.7 mm blade stock behind the edge. You're just compromising the slicing capability of such a thin blade. Delica is a great platform and deserves to shine. That's all.
P.S
Stop throwing stones at me :) . It's not a criticism I'm just trying to suggest an improvement of this iconic spydie. :spyder:
Marius
jpm2
Post by jpm2 »
How do you make the primary FFG any thinner given a set thickness and height? I must not understand geometry too well.
elena86 wrote:
Mon May 28, 2018 7:39 am
P.S
I actually agree with you, I hope you didn't feel I was throwing stones. I think most of us are just pointing out that too many people don't know how to use knives without breaking them, and Spyderco are the ones who will deal with the backlash so they have to engineer in some idiot proofing. I would love it if there were either sprints or separate production variants for AFI's, blades with thinner stock and thinner grinds aimed at higher performance for those who don't dismantle cars with their pocket knives. I think if they included a user advisory note like they do with the Civilian they might be able to protect themselves from dealing with broken blade warranties. There are just too many assumptions that "light use/duty" equals "weak/fragile/definitely gonna break" which translates into something people are afraid of buying. There are so many companies who push outright beatability as the benchmark that all knives are measured by that to market anything less is not a smart business practice. So, the general run 'o the mill production knife has to be made idiot proof and those of us who appreciate thinner blades are left with regrinds as a consolation prize.
All that aside, if you search enough through this forum and likely others you'll find LOTS of people and comments suggesting that the FFG Delica is fragile and not suited for more than opening your mail, and that the saber grind version was better. When there are so many people who value beatability over slicing performance, you can't blame Spyderco for playing it safe with their grinds.
knivesandbooks
Post by knivesandbooks »
I agree with Evil D. Plus, the Delica is supposed to be an afforadable, high value/high quality everyman's knife. It's not an afi knife and not a specialised knife. Performance wise as a single option cutting tool, it works fine. Works better than most.
Last edited by knivesandbooks on Mon May 28, 2018 11:15 am, edited 1 time in total.
tvenuto
Post by tvenuto »
P.S
No one is missing the point, your assertion that there is "no reason" and that it is "nonsense" are hyperbolic and do not invite discussion. Clearly there are costs and benefits to thickening or thinning blade stock, people have been listing the benefits of a thicker than "ideal" cutting geometry.
...and this has to be the most gentle stone throwing anyone has ever received on an internet forum.
elena86
Post by elena86 »
tvenuto wrote:
Mon May 28, 2018 10:47 am
P.S
1.Hyperbolic you say.... I say provocative....and it did work :p
2.Gentle throwing you say ... I say ... curved :rolleyes:
Marius
tvenuto
Post by tvenuto »
If by "worked" you mean the community showed it was able to resist the urge to start a flame war due to the wording of the OP, and then resisted once again when they were accused of it anyway, then I would agree with you. Thanks for verifying this is a very tolerant place.
elena86
Post by elena86 »
So, you're the spokesman for the community ? Why didn't you say so ? In that case you are allowed to keep trolling my thread. Enjoy !
Marius
gaj999
Post by gaj999 »
Evil D wrote:
Mon May 28, 2018 7:38 am
... If Spyderco made everything like the Nilakka they'd get branded as a fragile knife company that can't survive "real world use"...
Except my Nilakka is quite thick behind the edge. Once I went to my usual 10dps, I got a huge bevel. It really pissed me off. Another @!#$% folding crowbar. I'm pretty sure it was the last Spyderco I bought.
gaj999 wrote:
Mon May 28, 2018 4:10 pm
Obviously it was an example. It has 5mm thick blade stock and is a near zero grind. I'm pretty sure you get the point I was trying to make.
gaj999
Post by gaj999 »
Evil D wrote:
Mon May 28, 2018 4:17 pm
I get that your point is that Spyderco doesn't grind anything thin because of warantee costs. Yes, I do know that there are companies who do even worse. I don't buy from them either. I had hoped that my Nilakka would be "near zero grind". It isn't even close. Every time I look at that knife(or someone reminds me of it) it annoys me. So I sound off.
gaj999 wrote:
Mon May 28, 2018 4:34 pm
Well case in point, it WAS a full zero grind originally but too many complaints about chipping and edge fractures led them to giving it a small bevel. It is still near a zero grind, it's just thicker behind the edge than you expected because the blade stock is so thick and the blade height is so low, it's a wedge. This is why others have also mentioned going with thinner blade stock for this idea. You can zero grind a 2 inch thick bar of steel and it won't slice for crap, the grind is only part of the equation.
