A well used purple Native
StuntZombie
Post by StuntZombie »
I was able to get my hands on a couple of the 2009 forum Natives when they first came out, and while mine got used for a very short time, my girlfriend has been carrying hers ever since I gave it to her. Today I figured I'd take a couple shots of the knife, as it looks now.
As you can see, it's had a bit of a busy life. ;)
Chris
Jazz
Post by Jazz »
Good to see. :)
- best wishes, Jazz.
JCP1969
Post by JCP1969 »
used but not abused. :)
StuntZombie
JCP,
I don't know about that. Some of the stuff I've caught her doing with that thing would probably make most of us cry.
Chris
ICSK
Post by ICSK »
Well, there hasn't been an abundant amount of metal taken off the blade and the tip is still there. I also assume you're sharpening it for her. If anything, I'd call that a great user knife despite your girlfriend's tendency to use the wrong tool for the job. Plus, you haven't seen mine:
I missed out on the forum knife if you haven't guessed by now. Chances are that you did. I call it my ugliest idea. Slices like no other knife I've ever held though. Especially with that improperly sharpened mirror polish that I gave it.
StuntZombie
Wow, did you flat grind that thing yourself? What did you use?
Chris
ICSK
Post by ICSK »
StuntDouble wrote:Wow, did you flat grind that thing yourself? What did you use?
The name of the tool escapes me right now but it was basically a power drill equipped with a diamond coated dremel bit, rested the blade against a block of wood, and used lower RPMs to try to prevent blade warp. It took a long time though because that S30V is so ridiculously hard.
