Maintence question!
Kuolema
Maintence question!
Post by Kuolema »
Hey all!
Gotta question regarding cleaning off of rust! I know a lot of people use something such as Flitz to clean off rust specs and whatnot; but AFAIK this renders the knife unable from food prep (as Flitz is toxic :P), so my question is:
Is there a food-safe method to rust removal?
Thanx in advance :)
may it not be tricksy
Noumenon
Post by Noumenon »
Scotchbrite pads?
spoonrobot
Post by spoonrobot »
Noumenon wrote:Scotchbrite pads?
I'd advise against that. Scotchbrite pads scratch the steel and create an environment that is more inviting to rust in the future.
Proper rust removal should be done with 0000 steel wool. If you use it dry it's perfectly safe. Just blow the excess fibers away with compressed air or wash them out with tap water.
vampyrewolf
Post by vampyrewolf »
I've had no problems using autosol or metalglo to clean rust and oxidization over the years. Just wipe down with isopropyl and mineral oil afterwards.
Coffee before Conciousness
Noumenon
Post by Noumenon »
spoonrobot wrote:I'd advise against that. Scotchbrite pads scratch the steel and create an environment that is more inviting to rust in the future.
The plastic ones will scratch? I haven't tested so I really don't know but I am surprised.
araneae
Post by araneae »
Noumenon wrote:The plastic ones will scratch? I haven't tested so I really don't know but I am surprised.
If you mean the green ones, yes they will.
-Nick
Last in: N5 Magnacut
zombie
Post by zombie »
Kuolema wrote:Hey all!
Thanx in advance :)
I've used flitz on a knife I cut food with, I just thoroughly washed the blade with alcohol then dish soap afterwards. I wonder now as well if it's ok to do this?
you could try and use tooth paste to remove rust. I think you use one part non gel toothpaste to one part baking soda. I haven't tried this but heard it works.
J Smith
Post by J Smith »
I use flitz.
I just don't think enough of it will ever transfer to my food to worry about it.
[CENTER]0 0[/CENTER]
[CENTER]<[/CENTER]
[CENTER]\____/[/CENTER]
JT
Post by JT »
vampyrewolf wrote:I've had no problems using autosol or metalglo to clean rust and oxidization over the years. Just wipe down with isopropyl and mineral oil afterwards.
+1 on Autosol. Also, if one wants to polish the edge :cool: , this stuff works.
Toad310
Post by Toad310 »
Agree, a good cleaning. I do not think there would be enough of the product to hurt you.
