Hi all,
Could someone please let me know what the blades in the attached picture are?
The seller says Delica and Dragonfly. He says the steel is AUS-8 and AUS-8A, lengths are 170mm opened and 135mm long opened.
The bottom one looks like a Dragonfly but the top one??? :confused: The rounded point :confused:
Thanks in advance.
A little help if you please
- Mr Blonde
The bottom one is the first incarnation of the Dragonfly, an experimental model if you will. The top one does indeed look like an old Delica model (integral FRN clip) with simply a broken/reground tip.
I would especially keep the dragonfly, as its condition looks good enough to gain collector value.
Wouter
Wouter
- The Deacon
Yep, 1st Generation Dragonfly and slightly damaged but neatly repaired Delica. I agree with Wouter - the early D'flys are bound to become collectors pieces, I just snagged a SE (which is marked G-2 stainless), still looking for a PE. If you like CE and integral FRN clips, and the price is right, that Delica looks to be a decent user.
