A little help if you please
RAT 54
Post by RAT 54 »
Hi all,
Could someone please let me know what the blades in the attached picture are?
The seller says Delica and Dragonfly. He says the steel is AUS-8 and AUS-8A, lengths are 170mm opened and 135mm long opened.
The bottom one looks like a Dragonfly but the top one??? :confused: The rounded point :confused:
Thanks in advance.
Spyders - which models.jpg (43.6 KiB) Viewed 1538 times
Ian
turebrand
Post by turebrand »
Looks like a reground broken tip to me...
/Anders
Mr Blonde
Post by Mr Blonde »
The bottom one is the first incarnation of the Dragonfly, an experimental model if you will. The top one does indeed look like an old Delica model (integral FRN clip) with simply a broken/reground tip.
I would especially keep the dragonfly, as its condition looks good enough to gain collector value.
Wouter
Last website update: 09-11-2025 Instagram
Post by The Deacon »
Yep, 1st Generation Dragonfly and slightly damaged but neatly repaired Delica. I agree with Wouter - the early D'flys are bound to become collectors pieces, I just snagged a SE (which is marked G-2 stainless), still looking for a PE. If you like CE and integral FRN clips, and the price is right, that Delica looks to be a decent user.
fret
Post by fret »
Older Delica with reground blade tip. Looks just like mine. Someone broke the tip off, reground it, I bought it, works fine for me. I use it edc. Nice Dragonfly, older model, no "dent" on either one.
RAT 54
Post by RAT 54 »
Thanks all. Will let you know how I get on.
Ian
stonefrog
Post by stonefrog »
hey ian bad luck eh. was watching that aution click over. i can say that it wasnt me tho.
