Show your mods!
- Makunochimaster
Re: Show your mods!
- Manixguy@1994
Re: Show your mods!
MG2MNOSD 0002 / Do more than is required of you . Patton
Re: Show your mods!
Not sure it's visible, but it took so many disassemblies and reassemblies that I don't want to do it again without a bigger reason. Regardless, I converted my Stretch 2 XL Lightweight PD#1 to washers
. Had to grind down the FRN protrusions and find a fitting set of 0,2mm thick washers, pretty easy all in all.
Decided to do it as my Stretch rubbed the inside of the handles when opening due to the lateral pressure of my finger on the opening hole and I couldn't tighten the pivot enough to mitigate it while retaining the ability to open the knife at all, the support area wasn't wide enough. Now the action is much smoother, lateral play is non-existent, really happy how it turned out
Re: Show your mods!
SiC ball, medium spring, Ti ball cage, linerless Ti scales. I wanted to cover the bases, lol
Re: Show your mods!
The only original parts are the liners and washers
- Paul Ardbeg
Re: Show your mods!
Looking good and super smooth action! Where did you get the spring from and what is a SiC ball?
Re: Show your mods!
I got them from Ebay. There was a seller that sold the set of 2 medium springs and 2 Silicon Ceramic bearings.Paul Ardbeg wrote: ↑Thu Nov 28, 2024 2:51 pmLooking good and super smooth action! Where did you get the spring from and what is a SiC ball?
- razorsharp
Re: Show your mods!
Millie: Acid stone wash, painted black liner cavity so it pops. MGX Clip.
Subvert: Homemade damascus clip, Ritdyed the G10 Red, which is now wearing to orange along the edges which is kind of like a sunburst.
Endura: Classic poor Seki city quality control, had to flatten the handle internals as the titanium was completely warped from laser cutting (should've used waterjet or EDM), this was done with a glass plate and silicon carbide. This improved the action dramatically. I then zero ground the blade and re etched it as the factory etch sucked (Its had several sharpenings since then) and did a ferric anodizing to the Ti.
Gayle Bradley 2: Made it some Purple Juma scales.
Roc: Made it some white G10 scales, full flat ground it , and gave it a hand pulled satin.
- Manixguy@1994
Re: Show your mods!
My goodness ! You have been busy , all look awesome . MG2razorsharp wrote: ↑Wed Dec 04, 2024 2:01 am
markomartin
ChoilsChoilsChoils
Re: Show your mods!
Byrd Robin 2 G10 with a wharnie blade from a FRN Robin
Re: Show your mods!
Those para 3 scales look comfy.
- Manixguy@1994
Re: Show your mods!
Old style satin clip that I did a mod to today and will sit back for another knife in future . MG2MNOSD 0002 / Do more than is required of you . Patton
Re: Show your mods!
My last sprint run Spyderco's so far has been two Police4 's, Endura4 and a Dragonfly II. Either changed out the scales or dyed the Burgundy colored to black.
Re: Show your mods!
Swayback from wayback with modifications to facilitate spydie flick and front flip pictured next to a modified Advocate:
Details of the rounded front of the scale and added jimping to facilitate front flipping:
Front flip and spydie flick actions are fabulous!
- SpeedHoles
Re: Show your mods!
I like the added jimping there.Mako109 wrote: ↑Thu Dec 26, 2024 3:29 pmSwayback from wayback with modifications to facilitate spydie flick and front flip pictured next to a modified Advocate:
...also the Advocate was one I wanted at the time but for some reason just never grabbed one... Weren't they a bit prone to lock stick?
Going back to Caly.
Re: Show your mods!
[/quote]
[/quote]
Mine has a tiny bit but nothing to be concerned about. I still think the CQI Advocate is among Sypderco's better designs and I wish Spyderco would run the model through the iteration pipeline.
[/quote]
Re: Show your mods!
I took a torch to the clip from my Crucarta PM2 and bronzed the finish to go with the new N5 Avacado. It doesn't quite match the PVD coating, but it's close. IMO it makes the knife look better. It'll do until I can get a bronze LynchNW clip.
Re: Show your mods!
Here is a new Manix2xl- Crucarta I got in yesterday and tonight as I am still up messing around with stuff; I just tore this knife all down after taking a few pix of the before, taped off with frog tape, laid what I thought would fit the scales.
Then I proceeded to snake the scales, have a looksee.
Second spyderco I have attempted this with. Still cannot keep the minwax stain from leeching under the edges of the frog tape.
This one kept the lines cleaner than the first one, but it still has what I am going to call Character lol...
Re: Show your mods!
Added the OCD4EDC- Titanium ball cage and their spring in my Manix2 XL above. Really like this big knife.
