Show your mods!
Re: Show your mods!
#3401
Re: Show your mods!
#3402
ImageMG2
horzuff
Re: Show your mods!
#3403
Post by horzuff »
Not sure it's visible, but it took so many disassemblies and reassemblies that I don't want to do it again without a bigger reason. Regardless, I converted my Stretch 2 XL Lightweight PD#1 to washers :grin-big eyes . Had to grind down the FRN protrusions and find a fitting set of 0,2mm thick washers, pretty easy all in all.
Decided to do it as my Stretch rubbed the inside of the handles when opening due to the lateral pressure of my finger on the opening hole and I couldn't tighten the pivot enough to mitigate it while retaining the ability to open the knife at all, the support area wasn't wide enough. Now the action is much smoother, lateral play is non-existent, really happy how it turned out
gooeytek
Re: Show your mods!
#3404
Post by gooeytek »
SiC ball, medium spring, Ti ball cage, linerless Ti scales. I wanted to cover the bases, lol
Pacu0420
Re: Show your mods!
#3405
Post by Pacu0420 »
The only original parts are the liners and washers
Steel afficianado and Spyderco nut
Re: Show your mods!
#3406
gooeytek wrote:
Thu Oct 17, 2024 7:14 am
Looking good and super smooth action! Where did you get the spring from and what is a SiC ball?
gooeytek
Re: Show your mods!
#3407
Post by gooeytek »
Paul Ardbeg wrote:
Thu Nov 28, 2024 2:51 pm
I got them from Ebay. There was a seller that sold the set of 2 medium springs and 2 Silicon Ceramic bearings.
razorsharp
Re: Show your mods!
#3408
Post by razorsharp »
Millie: Acid stone wash, painted black liner cavity so it pops. MGX Clip.
Subvert: Homemade damascus clip, Ritdyed the G10 Red, which is now wearing to orange along the edges which is kind of like a sunburst.
Endura: Classic poor Seki city quality control, had to flatten the handle internals as the titanium was completely warped from laser cutting (should've used waterjet or EDM), this was done with a glass plate and silicon carbide. This improved the action dramatically. I then zero ground the blade and re etched it as the factory etch sucked (Its had several sharpenings since then) and did a ferric anodizing to the Ti.
Gayle Bradley 2: Made it some Purple Juma scales.
Roc: Made it some white G10 scales, full flat ground it , and gave it a hand pulled satin.
Re: Show your mods!
#3409
razorsharp wrote:
Wed Dec 04, 2024 2:01 am
My goodness ! You have been busy , all look awesome . MG2
markomartin
Re: Show your mods!
#3410
Post by markomartin »
My little friends.
John 3:16
ChoilsChoilsChoils
Re: Show your mods!
#3411
Post by ChoilsChoilsChoils »
Byrd Robin 2 G10 with a wharnie blade from a FRN Robin
Re: Show your mods!
#3412
markomartin wrote:
Thu Dec 05, 2024 6:18 am
My little friends.
John 3:16
Those para 3 scales look comfy.
Re: Show your mods!
#3413
Image Old style satin clip that I did a mod to today and will sit back for another knife in future . MG2
Re: Show your mods!
#3414
My last sprint run Spyderco's so far has been two Police4 's, Endura4 and a Dragonfly II. Either changed out the scales or dyed the Burgundy colored to black.
Mako109
Re: Show your mods!
#3415
Post by Mako109 »
Swayback from wayback with modifications to facilitate spydie flick and front flip pictured next to a modified Advocate:
Details of the rounded front of the scale and added jimping to facilitate front flipping:
Front flip and spydie flick actions are fabulous!
SpeedHoles
Re: Show your mods!
#3416
Post by SpeedHoles »
Mako109 wrote:
Thu Dec 26, 2024 3:29 pm
I like the added jimping there.
...also the Advocate was one I wanted at the time but for some reason just never grabbed one... Weren't they a bit prone to lock stick?
Going back to Caly.
Mako109
Re: Show your mods!
#3417
Post by Mako109 »
[/quote]
[/quote]
Mine has a tiny bit but nothing to be concerned about. I still think the CQI Advocate is among Sypderco's better designs and I wish Spyderco would run the model through the iteration pipeline.
Pacu0420
Re: Show your mods!
#3418
Post by Pacu0420 »
I took a torch to the clip from my Crucarta PM2 and bronzed the finish to go with the new N5 Avacado. It doesn't quite match the PVD coating, but it's close. IMO it makes the knife look better. It'll do until I can get a bronze LynchNW clip.
Re: Show your mods!
#3419
Here is a new Manix2xl- Crucarta I got in yesterday and tonight as I am still up messing around with stuff; I just tore this knife all down after taking a few pix of the before, taped off with frog tape, laid what I thought would fit the scales.
Then I proceeded to snake the scales, have a looksee.
Second spyderco I have attempted this with. Still cannot keep the minwax stain from leeching under the edges of the frog tape.
This one kept the lines cleaner than the first one, but it still has what I am going to call Character lol...
Re: Show your mods!
#3420
Added the OCD4EDC- Titanium ball cage and their spring in my Manix2 XL above. Really like this big knife.
