Evil D wrote: ↑Thu Jun 19, 2025 10:47 am
vivi wrote: ↑Thu Jun 19, 2025 10:09 am
So the question for this thread is, what exactly are you gaining from a thin/acute blade tip?
Let me answer your question with another question.
What exactly are you gaining from thin / acute edge geometry in general?
efficiency.
Why don't I EDC an axe and poke holes in things with it?
A knife works better.
If my catcherman, chief and military 2 can poke holes in things without failing, why would I want a thicker tip?
There's no advantage to me having a thicker tip if the thin tips I use work fine without failing.
There's no advantage to me using the thick factory edge geometry knives ship with if my ~10dps edge I put on every knife holds up fine.
You tell me what exactly you're doing to break knife tips and I can tell you what exactly you're doing your knife wasn't meant for.
I can rock the same philips screwdriver on a multitool for a decade too. *shrug*
Well like I openly admitted much of it is hypothetical, it's been so long since I broke a blade tip I don't even remember the last time. I guess the answer is I don't find myself using them and wishing they were thinner, so maybe I'm just ignorant of the average performance I'm getting?
I guess I'm a little confused as to what answer you expect.
Knives cut things. Thinner knives cut things with less effort. This is true for both edges and tips.
The "thinly tipped" knives you, wartstein and others fret over have never failed me after using them for 25+ years.
I've never broken a tip off a Police, Opinel, Swiss Army Knife, chef knives, Native Chiefs, Military 1 or 2 etc.
Why don't you sharpen your knives at 50 degrees per side? They could still cut the things you use your pocket knives for.
Easy. Because it's a less efficient edge angle than 20 degrees per side, or whatever you personally sharpen at.
There's no real mystery here, except why other people aren't interested in figuring out the limits of things.
I bought a Cold Steel 4 Max. It's an awesome knife. Great action, well made, some of the best ergonomics of any folders I own.
But I also never carry it.
Why?
Becauwe the Cold Steel Recon does 99% of the things I use pocket knives for better.
That extra 1.5-2mm of steel stock resulting in a thicker edge and tip does not benefit me at all unless I want to chop wood with a folding knife. Which is a very rare circumstance to find myself in.
So I carry the Recon instead of the 4 max because I find it more efficient.
If I handed most people a factory edged Victorinox chef knife they'd think it's the sharpest kitchen knife they've ever used.
If they tried my aogami super 10" gyuto I just used at work, well, most folks that have tried it are literally afraid of how easily it cuts.
It's all relative.
If you're used to 30 degree per side edges my 10 degree per side edges my sound like insanity.
But my edges angles (and my tip preferences) are based on real world data - data on when things fail.
I've brought many knife edges to the point they were too thin and they started to fail. So I know how thin I can run a knife edge and still be fine.
Most people don't do this. They just guess or go with the factory edge.
I guess I'm just curious in that way. I also had to find out how many hours I could skateboard before my body stops working, how many miles I can bike in a day before my legs stop working, etc.
It's all about efficiency. Why use a thicker edge or tip than I have to and make myself work harder? It'd be like going to work with ankle weights on.
