vivi wrote: ↑Tue Jun 17, 2025 8:48 amknife tips are only fragile when they aren't treated as knife tipsEvil D wrote: ↑Tue Jun 17, 2025 5:59 amI thought the tip of the Chief was fragile until I compared it to a Military 2, they're nearly identical up until the shape of the spine changed and by that point you're past the point of it being thin enough to call it fragile. This seems especially true for the Military 2 which seems to be ground thinner than the Military 1. Maybe this just means the Military 2 has a fragile tip too?
never broke a chief tip, catcherman tip,military 1 or 2 tip, etc. been carrying them for decades.
It's just one of those things like your aversion towards carrying a compression lock and the potential of it opening in your pocket or wasteband, lots of people have never had that happen either but for you it's a real concern. For someone that's broke a blade tip, whether we agree that it's a reasonable use or abuse, it's still a concern for them. I don't personally have a need or see an advantage of a paper thin acute blade tip, I can make holes with my Microtechs just fine and without much concern for breaking off the tips (beyond maybe chipping the actual point, but IMO that's edge damage and a different situation). For me there's definitely a point (pun intended) where a thinner tip is more of a liability than an advantage.
I think for this debate the shape of the blade is more important than the thickness or distal taper, you could grind the tip of a Chief thicker for those that want it to be more durable and it would still poke holes just fine. The original Worker had a really thin tip but wasn't what I'd call fragile.
So the question for this thread is, what exactly are you gaining from a thin/acute blade tip?
What are you poking holes in? I really feel like this is a "no wrong answer" debate but I really just rarely have a need to do so at all, and I'll freely admit that my preference for a stronger tip is more about potential damage than from any real world experience.
Back when I was towing I did fix many car bumpers by "zip tie lacing, aka race lace" and for that I had to drill several holes into a urethane bumper to run zip ties through, but I always used my multitool awl because it's literally designed for such a task and makes perfect holes.
I don't use my knifes as screwdrivers or pry bars, but even though I'll always argue that there's a better tool for the job than the tip of a knife, I still feel like stronger is better. Maybe if I saw some kind of benefits then I'd be more open to splinter pickers?
And there absolutely is an opposite end of this spectrum where blade tips are too blunt and may as well be round, an example would be a ZT0300 series, where you definitely won't be breaking the tip but also probably not poking holes into anything either.
