Show your Mule
ykspydiefan
Re: Show your Mule
#1361
Post by ykspydiefan »
Still needs some sanding and clear coat.
Re: Show your Mule
#1362
Ha! That's awesome. Love the glow pattern! Might have to copy your idea sometime...!
Xplorer
Re: Show your Mule
#1363
Post by Xplorer »
The GID looks cool. Great job getting your Mule handled! :)
@ckc_knifemaker on Instagram.
ykspydiefan
Re: Show your Mule
#1364
Thanks Team.
standy99
Re: Show your Mule
#1365
Post by standy99 »
Coming along
legOFwhat?
Re: Show your Mule
#1366
Post by legOFwhat? »
Looking fantastic! Makes me wanna try the larger pin holes.
-Larry
MNOSD #0049
standy99
Re: Show your Mule
#1367
Post by standy99 »
legOFwhat? wrote:
Sat Jul 17, 2021 8:47 pm
Went a bit crazy with mosaic pins, pins and copper, brass tubes when I ordered some stuff because they were so cheap. :D
Do think the large brass lanyard tubes came out good on this colour Micarta. Glad I didn’t put the middle one in now…
Knivesofaspyder
Re: Show your Mule
#1368
Post by Knivesofaspyder »
standy99 wrote:
Sat Jul 17, 2021 5:30 am
Coming along
What size tubes did you use here?
Re: Show your Mule
#1369
Are you relying on the epoxy to keep it together, or are those tubes flared also? If flared, did you likewise flare the G10 before assembly?
standy99
Re: Show your Mule
#1370
Post by standy99 »
Bolster wrote:
Sun Jul 18, 2021 10:08 pm
The amount of epoxy all the little unused circles in the mule handle take up there is enough epoxy for keeping it all together. (If I was doing a solid piece tang without any cut outs I would use Corby bolts)
The lanyard tubes just add to the no movement aspect of the handle scales.
I use a 12 hour epoxy on handles with pins.
Leksy
Re: Show your Mule
#1371
Post by Leksy »
This is one of my Mules. I bought it a while ago on a secondary market, in a rather abused condition, with poor quality scales and sheath, and some kind of polish on the blade, which is heavily pitted. I believe, this Cruwear blade has "factory pitting" after re-heat process during the recall campaign (mentioned earlier somewhere on this forum), because these pits are presented along the entire blade (even under the scales), and they aren't getting larger or deeper, so it's mostly a cosmetic issue.
Nevertheless, I decided to give it the second life. Brought it to local knife craftsman, he made these two-layer micarta scales, and set them up with epoxy resin and titanium pins. Then I sharpened it to around 11 dps with high-grit stones to near-mirror finish. The handle feels warm and super comfortable, and fits perfectly into Spyderco branded leather sheath. This Mule doesn't see much work, but it's definitely a pleasure to use it ;)
Re: Show your Mule
#1372
Leksy wrote:
Mon Jul 19, 2021 3:44 pm
Definitely jealous of those handles - I've got some nice 3D G-10 scales on my PD1 mule, but nothing beats Micarta. And that double layer effect is super cool!
Re: Show your Mule
#1373
Very handsome. Hats off to the restoration.
standy99
Re: Show your Mule
#1374
Post by standy99 »
standy99
Re: Show your Mule
#1375
Post by standy99 »
Knivesofaspyder wrote:
Sun Jul 18, 2021 8:21 pm
Brass Lanyard Tube 3/8" (9.525 mm x 300 mm)
Dane
Re: Show your Mule
#1376
Post by Dane »
One arriwed safely in Texas:
Murat_Cyp
Re: Show your Mule
#1377
Post by Murat_Cyp »
The handle material is G-carta, the fit and finish on Kydex is excellent! It is made by a fellow member from UK forums. Now, all it needs is a good sharpening as the factory edge does not look too good.
Dane
Re: Show your Mule
#1378
Post by Dane »
Here is my latest mule.....i like how it turned out.
Rp5
Re: Show your Mule
#1379
Post by Rp5 »
Dane wrote:
Wed Aug 25, 2021 2:17 am
Wow, me too.
petz462
Re: Show your Mule
#1380
Post by petz462 »
First Mule:
today the UPS guy dropped the box off on the front porch. I went out and opened it on my trucks tailgate, Z-WEAR mule was shining. Walked out to the mailbox and lo and behold there was a small package from Halpern, inside were Option 5 Battleship Gray scales. A twofer. Quickly assembled, Yahoo!! Went to backyard and snapped this photo against a Northwest Florida Live Oak. A good day I must say!!
Dave
Dave
USAF Retired
