Show your Mule
Re: Show your Mule
Still needs some sanding and clear coat.
Re: Show your Mule
Ha! That's awesome. Love the glow pattern! Might have to copy your idea sometime...!
Re: Show your Mule
The GID looks cool. Great job getting your Mule handled! :)
@ckc_knifemaker on Instagram.
Re: Show your Mule
Thanks Team.
- legOFwhat?
Re: Show your Mule
Looking fantastic! Makes me wanna try the larger pin holes.
-Larry
MNOSD #0049
MNOSD #0049
- standy99
Re: Show your Mule
Went a bit crazy with mosaic pins, pins and copper, brass tubes when I ordered some stuff because they were so cheap. :DlegOFwhat? wrote: ↑Sat Jul 17, 2021 8:47 pmLooking fantastic! Makes me wanna try the larger pin holes.
Do think the large brass lanyard tubes came out good on this colour Micarta. Glad I didn’t put the middle one in now…
Re: Show your Mule
Are you relying on the epoxy to keep it together, or are those tubes flared also? If flared, did you likewise flare the G10 before assembly?
- standy99
Re: Show your Mule
The amount of epoxy all the little unused circles in the mule handle take up there is enough epoxy for keeping it all together. (If I was doing a solid piece tang without any cut outs I would use Corby bolts)
The lanyard tubes just add to the no movement aspect of the handle scales.
I use a 12 hour epoxy on handles with pins.
Re: Show your Mule
This is one of my Mules. I bought it a while ago on a secondary market, in a rather abused condition, with poor quality scales and sheath, and some kind of polish on the blade, which is heavily pitted. I believe, this Cruwear blade has "factory pitting" after re-heat process during the recall campaign (mentioned earlier somewhere on this forum), because these pits are presented along the entire blade (even under the scales), and they aren't getting larger or deeper, so it's mostly a cosmetic issue.
Nevertheless, I decided to give it the second life. Brought it to local knife craftsman, he made these two-layer micarta scales, and set them up with epoxy resin and titanium pins. Then I sharpened it to around 11 dps with high-grit stones to near-mirror finish. The handle feels warm and super comfortable, and fits perfectly into Spyderco branded leather sheath. This Mule doesn't see much work, but it's definitely a pleasure to use it
- kennethsime
Re: Show your Mule
Definitely jealous of those handles - I've got some nice 3D G-10 scales on my PD1 mule, but nothing beats Micarta. And that double layer effect is super cool!Leksy wrote: ↑Mon Jul 19, 2021 3:44 pmNevertheless, I decided to give it the second life. Brought it to local knife craftsman, he made these two-layer micarta scales, and set them up with epoxy resin and titanium pins. Then I sharpened it to around 11 dps with high-grit stones to near-mirror finish. The handle feels warm and super comfortable, and fits perfectly into Spyderco branded leather sheath. This Mule doesn't see much work, but it's definitely a pleasure to use it
- standy99
Re: Show your Mule
- standy99
Re: Show your Mule
Brass Lanyard Tube 3/8" (9.525 mm x 300 mm)
Re: Show your Mule
One arriwed safely in Texas:
Re: Show your Mule
The handle material is G-carta, the fit and finish on Kydex is excellent! It is made by a fellow member from UK forums. Now, all it needs is a good sharpening as the factory edge does not look too good.
Re: Show your Mule
Here is my latest mule.....i like how it turned out.
Re: Show your Mule
First Mule:
today the UPS guy dropped the box off on the front porch. I went out and opened it on my trucks tailgate, Z-WEAR mule was shining. Walked out to the mailbox and lo and behold there was a small package from Halpern, inside were Option 5 Battleship Gray scales. A twofer. Quickly assembled, Yahoo!! Went to backyard and snapped this photo against a Northwest Florida Live Oak. A good day I must say!!
Dave
Dave
Dave
USAF Retired
USAF Retired
