What model SharpMaker is this?
eldiablojoe
Post by eldiablojoe »
I was reading a thread on SharpMakers and someone referenced a model 204 and a 701. Which is this old one of mine? It has no fancy integrated case/cover.
Also, the other threads and Sal's videos keep talking about being set at 30 and 40 degrees. My SharpMaker CLEARLY indicates it is set for 20 degrees (Upper right Illustration #1 of back cover), which leaves me :confused:
I also noticed when I was sharpening my new BayouShooter Emerson Endura this afternoon, when in the upright flat position, the stone is not totally flat facing each other, but actually twist a little bit out ever so slightly (as seen in fourth photo). Is this normal?
jujigatame
Re: What model SharpMaker is this?
Post by jujigatame »
Your Sharpmaker is fine. The 20 degrees is per side and that will give you a 40 degree edge in total. Later models added slots for 15 degrees per side/30 degrees total.
I can't really see any twist to the rods but the base slots may allow for play/movement in the rods when you use it.
~ Nate
hiredgun
Post by hiredgun »
The 203!
Stuart Ackerman
Post by Stuart Ackerman »
I love that...
Quality is the product of a good attitude...
rycen
Post by rycen »
203MF
eldiablojoe
Is that for Multi-Function, or Mother F-er?
rycen
Post by rycen »
It stands for medium fine in reference to the two different sets of rods included.
LC Kid
Awesome Vintage!
Post by LC Kid »
Hi eldiablo!
What a fantastic Vintage SharpMaker! :spyder:
I'm sure it works as good as any 'new' SM version. :D
WireEdge Roger
Post by WireEdge Roger »
I still have my original set, works like a charm too.
rodloos
Post by rodloos »
Yep, as others have pointed out, it's the 203 (you can even see the 203 MFC part number on the manual in one of the pictures posted).
I still have mine. Back then the optional diamonds weren't triangular rods like today, but were "sleeves" that slid down onto the regular rods.
I can't remember when I bought mine, but it must have been in the 1980's (back when there were knife stores in malls, pre-internet! :) )
