Stripping DLC off the blade
Art_vandeley
Post by Art_vandeley »
Hey,
I have an extra DLC blade for my Para 2, and I want to strip off the coating for some variety. How would one do that to get the best result?
Sandpaper?
jackknifeh
Post by jackknifeh »
Have you tried stabbing car hoods? Cold Steel's black (not DLC) seems to come off pretty easy when doing that. lol
I've been impressed with how durable DLC is. For a nice job you may need to send it to the guy people here send blades to to get re-ground. Saber grind to FFG for instance. That should do it.
Jack
Leatherneck
Post by Leatherneck »
I was able to strip the coating off of a Benchmade with a scotchbrite pad and steel wool. That isn't going to happen with Spyderco's DLC at least not before your arm is in a sling! It is some tough stuff.
I'm sure there is a way though but I am assuming it won't look like a pristine satin blade at first.
USMC RETIRED
[SIGPIC][/SIGPIC]
jackknifeh
Art_vandeley wrote:Hey,
Sandpaper?
Just curious, how did you end up with an extra blade?
Jack
Art_vandeley
jackknifeh wrote:Just curious, how did you end up with an extra blade?
Jack
I bought a Para 2 from a guy on Youtube for 20$. Unfortunately the lock is shot to pieces, and it has extreme blade play no matter how hard I tighten it up. So I swapped the gray scales it came with my black on my edc Para, and keep the screws and other parts as spares for it. So now I have a spare blade with some chips and dings in it, and I`d like to see if I can strip the coating to see how it`ll look.
Uploaded with ImageShack.us
I tried with some sandpaper, but it`ll take some elbow grease to make it nice.
Stefan Roth
Post by Stefan Roth »
I offer you a deal. Send me the black one, I send you a regular one.
Art_vandeley
Stefan Roth wrote:I offer you a deal. Send me the black one, I send you a regular one.
You want a black & black one? How is the lock on yours? Any sticking?
jackknifeh
Art_vandeley wrote:I bought a Para 2 from a guy on Youtube for 20$. Unfortunately the lock is shot to pieces, and it has extreme blade play no matter how hard I tighten it up. So I swapped the gray scales it came with my black on my edc Para, and keep the screws and other parts as spares for it. So now I have a spare blade with some chips and dings in it, and I`d like to see if I can strip the coating to see how it`ll look.
Sounds like a good deal. Do you have, or have access to a Dremel? I'd love to see how a Dremel with good sanding accessories does on DLC. If the Dremel wouldn't do a good job that would speak VERY highly of DLC. I imagine if you had a Dremel you would have tried it. Dumb question probably.
Has anyone reading this ever tried a Dremel or equivalent on DLC?
Jack
jackknifeh
Art_vandeley wrote:You want a black & black one? How is the lock on yours? Any sticking?
FYI: You both are pretty new here. There's a rule against buying or trading on the forum. Not sure why but that's Spyderco's policy. You might want to communicate some other way. Good luck on a trade.
Jack
Art_vandeley
jackknifeh wrote:Sounds like a good deal. Do you have, or have access to a Dremel? I'd love to see how a Dremel with good sanding accessories does on DLC. If the Dremel wouldn't do a good job that would speak VERY highly of DLC. I imagine if you had a Dremel you would have tried it. Dumb question probably.
Jack
I have a cheap Dremel ripoff, that probably sets itself on fire the next time I turn it on. But I`m interested as well on how a dremel fairs against the DLC. From what I can observe the DLC is really really tough. Mayb if I can get a dremel at a nice price (one day) I`ll try it out on the spare blade.
Thanks Jack. Didn`t know about the no trade rule. I`m in the chat right now btw.
Also here is a pic of both the locks before I switched scales:
jackknifeh
Art_vandeley wrote:I have a cheap Dremel ripoff, that probably sets itself on fire the next time I turn it on. But I`m interested as well on how a dremel fairs against the DLC. From what I can observe the DLC is really really tough. Mayb if I can get a dremel at a nice price (one day) I`ll try it out on the spare blade.
For the price of a new Dremel 4000 and different accessories and attachments you can get one or two really nice Spyderco's. I got one a couple of years ago and now I wonder how I got along without it. I don't use it very often like one would for a hobby but for some things it makes the job 100 times easier. I have used it to make scales and wouldn't try it I don't think if I didn't have the Dremel (or something else). The Dremel is one of those things you can live without until after you have had one for a while. I can only think of one tool that is more important than a Dremel. What is that tool? I'm having a hard time remembering now. Oh yeah, a Spyderco knife. lol (still can't find smilies)
Jack
Slash
Post by Slash »
Try soaking it in vinegar for about a week. Check it every couple days to see if you're making any progress.
jackknifeh
Slash wrote:Try soaking it in vinegar for about a week. Check it every couple days to see if you're making any progress.
I have to ask. Why do you think vinegar would work? Were you joking but couldn't find a smilie (like me) to indicate a joke?
Jack
Be careful with that Dremel - overheating the blade could affect your heat treat.
darkstar29
Post by darkstar29 »
Brock O Lee wrote:Be careful with that Dremel - overheating the blade could affect your heat treat.
Very true.. I'd try the brass wire bit.. Or some stiffer wire. Then polish the heck outta it.
I walk away slow tonight,
and cut through the air
with a curse, like a knife.
PARATOM
Post by PARATOM »
just wondering...did you buy that one off they guy who did the torture test on the comp. lock?
i watched that video and it hurt to watch it, but it looks like the same knife, same jacked up comp. lock and everything, link below
http://www.youtube.com/watch?v=wEH2erOh5Zw
[LEFT]Para 2 digi cam/DLC | Tenacious PE | Sage 1 | Delica 4 FFG | Manix 2 | Dragonfly 2 H1 | Yojimbo 2 | SmallFly digi cam R | Citadel DLC R[/LEFT]
There are two kinds of people in this world, you're either somebody or nobody...
Jay_Ev
Post by Jay_Ev »
Yikes, it hurt to watch that video.
phillipsted
Post by phillipsted »
I was thinking the same thing.
FYI. When Neptune disassembled the Para2 after beating the cr@p out of it - he voided the warranty. :eek:
TedP
phillipsted wrote: FYI. When Neptune disassembled the Para2 after beating the cr@p out of it - he voided the warranty. :eek:
LOL! Thats the funniest thing I heard all day!
Art_vandeley
PARATOM wrote:just wondering...did you buy that one off they guy who did the torture test on the comp. lock?
Yeah that`s the one :P
20 bucks was a good deal, and the grey scales are pretty fine.
He also cut S30V with CTS20CP. Don`t watch if you love your spydies.
http://youtu.be/buHwSusTHBE
I made a small vid once I got it tho. I sharpened out the dings the sawing made, and it`s fine now.
http://youtu.be/86sdAbL_ABg
Btw. I take apart all my Spydercos. Once done you can really appreciate the engineering that went into them. Especially the Para 2 is a joy to disassemble.
