M4, Superblue? Your patination tips and pics.
hunterseeker5
Post by hunterseeker5 »
Chris_H wrote:Yes, you can remove patina from steel with either a polishing compound or sanding it off. In this thread, though, most want to know how to get it.
As a follow up to this you'll have some difficulty removing it with anything other than elbow grease. The "black" buildup is a process called reduction. The orange/reddish bits are oxidation. The two processes are both reversible, but they're each other's antithesis, so to remove oxidation you usually cause reduction and vice versa. In theory chelation will remove both but in practice chelation agents are not pH neutral so you'll end up with one or the other. Bottom line? What he said. Buff it off. ;) :p
lambertiana
Post by lambertiana »
Orion's Belt wrote:I've cut all types of acidic fruits and stuff with my GB and there's no trace of patina. I think the previous owner put some Tuff Glide on it. Time will tell if it will ever develop a patina or not.
I have noticed that my GB is very slow to patina. The Caly SB takes a patina much faster, just like plain old 1095.
feed_the_animals
Post by feed_the_animals »
Gorgeous patina on the Caly, OP.
xavierdoc
Post by xavierdoc »
feed_the_animals wrote:Gorgeous patina on the Caly, OP.
Thanks. There have been so lovely pics posted.
One of the things I love about blades with a patina is the contrast it gives with a polished bevel. That, with the gradation of tone behind the bevel from stropping, make sharp edge look even sharper! It's like a "1000 yard stare" for knives; "I've seen and done some things".
I've noticed the patina on the SB is prone to reddish change which I prefer to clean off.
UKPK G10, UKPK Ti, Para 2CF&20CP, Stretch CF, Stretch CF conv, Manix2 M4,Endura Wave, Endura ZDP189, Pacific Salt, Captain, Gunting S30v, P'Kal, Gayle Bradley,Atlantic Salt, Spyderhawk, Crossbill, Wings slipit
Mules: CTSBD1, Super Blue, S90V, VG10, S35VN, Cos-3, M390 Fixed: Bushcraft, Warrior
xceptnl
Post by xceptnl »
D2 forced patina. I have removed quite a bit from the other side, but it is turning out to be quite the ordeal. I think I'm going to just give up and use it. When it starts to look really dark again I will just stonewash it.
*Landon*
kbuzbee
Post by kbuzbee »
Gayle Bradley sees a lot of use. The M4 patina is great!
Ken
玉鋼
phillipsted
Post by phillipsted »
I can't wait to get the Air and see the patina on that small gentleman's knife!
TedP
Worry less - Breathe more...
Spydie Fanatic #185
kbuzbee
Post by kbuzbee »
phillipsted wrote:I can't wait to get the Air and see the patina on that small gentleman's knife!
TedP
Yep, looks totally sweet!
Cheers,
Ken
玉鋼
lambertiana
This is after only a couple apples, the SB gets a patina quickly.
KardinalSyn
Kard's SB Caly3.5 patina
Post by KardinalSyn »
I used a lime to get this Patina.
And the other side
I could not get the same effect as you can see. :o
DaRTH SfaRi
Post by DaRTH SfaRi »
I rarely use any of my collector spydies to cut anything...is it safe to say my caly sb won't patina if it jus sits on my wall?..dry climate
Perrin PPT*Tasman Salt*Leafstorm*Persistence*Kiwi SS Lockback*Stretch*Caly 3.5 Super Blue Sprint Run*Matriarch 2* SmallFly*Endura 4 FFG Orange*Schempp Rock*Endura 4 ZDP-189*
Fat Goat Forge
#32
Post by Fat Goat Forge »
kbuzbee wrote:Gayle Bradley sees a lot of use. The M4 patina is great!
Ken
Is that a natural patina that developed over time? Or did you force it?
I just got my GB and am loving it. I just did the mod where you dremel out a bit of scale and liner to allow unfettered access to the spyderhole and liner lock.
Loving this knife!
If that is the natural patina I am just going to wait it out as it looks good.
George in maine
kbuzbee
#33
Post by kbuzbee »
Fat Goat Forge wrote:Is that a natural patina that developed over time?
I wiped it down initially with white vinegar which left it a light grey, it's proceeded from there. I have a second one I soaked for a couple hours. It looks very similar.
M4 forms the best patina, IMO. I love that about it (though I haven't tried any SB yet)
Cheers,
Ken
玉鋼
w3tnz
#34
Post by w3tnz »
xceptnl wrote:D2 forced patina. I have removed quite a bit from the other side, but it is turning out to be quite the ordeal. I think I'm going to just give up and use it. When it starts to look really dark again I will just stonewash it.
Does the D2 steel take to this as well as the superblue/m4? Or is it quite hard to stain?
I see, said the blind man.
kbuzbee
#35
Post by kbuzbee »
w3tnz wrote:Does the D2 steel take to this as well as the superblue/m4? Or is it quite hard to stain?
IMO, nothing at all like M4. Three days soaking in vinegar made maybe a 10% difference. I'd classify it as almost stainless.
Ken
玉鋼
gooeytek
#36
Post by gooeytek »
xavierdoc
#37
Post by xavierdoc »
gooeytek wrote:Image
Ooooh, yeaaah! That's one of my grail knives and with that patina- perfect.
w3tnz
#38
Post by w3tnz »
*update, got hold of them was an error on their site, have placed an order :D
DaRTH SfaRi
#39
DaRTH SfaRi
#40
Got tired of the inevitable and forced my own patina
