What STEEL would you want on the next MULE?
What steel would you want to see on an upcoming mule? (multiple choices allowed)
Elmax
39
21%
CTS - XHP
9
5%
CTS - 20cp
8
4%
CPM - 3v
16
9%
CPM - 10v
24
13%
CPM - s110v
53
28%
CPM rex 121
14
7%
Bohler s790 microclean
12
6%
Bohler n680
3
2%
OTHER - please post it below!
9
5%
Total votes: 187
Random Chance
Post by Random Chance »
I've read enough about CPM-10V that my interest is piqued. I would love to have a chance to try it out. I also voted Bohler s790 just because I've never run across this one before.
jtoler_9
Post by jtoler_9 »
Sleipner. Not sure about the spelling. But I see it in some Lion Steel stuff. Looks interesting.
SuperFist
Post by SuperFist »
Most definitely a Crucible Industries CPM - s110v Mule.
Sf.
Halfneck
Post by Halfneck »
L6.
"A Delica is still a better weapon than a keyboard and a sour attitude..." Michael Janich
gundude73
Post by gundude73 »
either Vanax 35 or Vanax 75 would be cool.
Digicam Military
Digicam Paramilitary 2
Ladybug
Honeybee
Salt 1
Baliyo
-Matt
Fred Sanford
Post by Fred Sanford »
The last Mule I bought was a CPM-M4 Mule and I loved it. I'd love to grab up another one and then have someone make handles for me again.
S110V sounds fantastic to me. :)
DCDesigns
Post by DCDesigns »
gundude73 wrote:either Vanax 35 or Vanax 75 would be cool.
I just found out about these, Im really curious. A ton of vanadium, almost no carbon. Any one have info on these steels? Id love to know the pros and cons, and ideal uses for it! New steel excites me.
VashHash
Post by VashHash »
I voted 110V. Kershaw tried to offer this steel in a limited run but I feel their heat treat fell short I would like to try it with a spyderco heat treat. Does crucible even offer REX steels anymore?
defenestrate
Post by defenestrate »
Would like to see a couple of common carbon steels like 1095 and A1 to have the :spyder: treatment done to the blades and compare with other older tool steel implements I use.
defenestrate
or CPM3V
gundude73
Post by gundude73 »
DCDesigns wrote:I just found out about these, Im really curious. A ton of vanadium, almost no carbon. Any one have info on these steels? Id love to know the pros and cons, and ideal uses for it! New steel excites me.
the only knife that i know of that uses either is the kershaw tilt. you can see various edge retention tests on it. ankerson has one on bladeforums.
so far i like the steel. i think its right up spyderco's alley.
Digicam Military
Ladybug
Honeybee
Salt 1
Baliyo
-Matt
SQSAR
#32
Post by SQSAR »
defenestrate wrote:Would like to see a couple of common carbon steels like 1095 and A1 to have the :spyder: treatment done to the blades and compare with other older tool steel implements I use.
That's a good idea. As much as I love the new "super-steels" I'd take at least one in 1095. That's a classic steel if there ever was one.
kadinh
#33
Post by kadinh »
s110v for me...no questions asked. and i would put carbon fiber scales with yellow liners fo sho!
You should never have to ask yourself "do i really need another knife?" The answer is obvious...
datoudaw
#34
Post by datoudaw »
DCDesigns wrote:Im pretty sure thats not going to happen. DLC is most likely out for mules. As somone who makes their own scales, I can tell you this would create a big problem if the blade were dlc'd prior to flushing up the scales. Besides S110v is already so expensive, any added costs might make it not worth making for spyderco.
Do you know how much extra for DLC coating would add to the cost? I thought we are talking about experimenting new "steels" for the fun of it. Hard coating on hard steel is fun to try. May not be too practical in the long run, however.
I do not understand what do you mean by "flushing up" the scales. I have done four DLC coated MTs and did not seem to have any problems with scales I made myself.
Zenith
Post by Zenith »
Nitrobe 77 but there is no more stock to my knowledge :(
RevDevil
#36
Post by RevDevil »
I voted for the S110V, although, I would much rather see that steel used in a Manix2, Para2, or Military.
jossta
#37
Post by jossta »
Baby steps :) . Also would like to see PD1, but S110v are 10v are what I want most.
DCDesigns
Post by DCDesigns »
datoudaw wrote:Do you know how much extra for DLC coating would add to the cost? I thought we are talking about experimenting new "steels" for the fun of it. Hard coating on hard steel is fun to try. May not be too practical in the long run, however.
- no mule has been coated yet, and probably wont be since they are supposed to be exactly the same other than steel. Its just not likely to happen. Most knives are kicked up another 10 bucks or so for the DLC version. The s110v mule will probably be the most expensive yet, costing more that the COs at 85+.
- how did you make your scales fit 100% flush with your handle without scratching off the DLC? Some steel stock has to be removed in my experience. Thats what I mean from "flushing up scales" - making them fit flush. Did you DLC them after the scales were built? Thats the only way you could do it without scratching the coat.
Any pictures for proof? Id like to see a DLC'd mule!
jossta
#39
Post by jossta »
Yeah, I don't think a stainless mule is one they'll start coating on either. I do love DLC though.
DCDesigns
Post by DCDesigns »
Zenith wrote:Nitrobe 77 but there is no more stock to my knowledge :(
good god what is that? sounds like a scifi show or something...
