Your TRUE WORKHORSE Spyderco Knife
Infinite Zero
#61
Post by Infinite Zero »
Either my VG-10 Caly 3.5, or the Super Blue sprint. Both are very easy to carry, and perform well.
Mr Blonde
Post by Mr Blonde »
My 440v Military has been with me the longest, and it still sees use. But for the past few years my Stretch 2 has been prominent carry folder. Give it a couple of years and it will truly become my most used folder.
Last website update: 09-11-2025 Instagram
jossta
#63
Post by jossta »
Gayle Bradley
PaulVB
#64
Post by PaulVB »
My Tasman Salt. You can use it hard & put it away dirty.
One of my many Calys.
yowzer
#66
Post by yowzer »
The SE Spyderhawk H1 and Stretch FRN/ZDP-189 are my hardest-used Spydercos.
Newest :spyder: in hand: Halloween Handle Hap40 Endura and Delica.
Talum15
#67
Post by Talum15 »
The Para 1 & G10 Delica are the most for me. Even swapped the blade of my delica with the thicker hollow ground, makes it more heavy duty.
Jazz
#68
Post by Jazz »
I figured people might want to see the workhorse I spoke of, so I had to take a few shots...
- best wishes, Jazz.
Hector Castro
#69
Post by Hector Castro »
Mine is a C52 Calypso Jr with the laminated ZDP and 420. It is light weight, sharp as a razor, and sheeple friendly. This thing cuts through stuff like a laser and stays sharp for a very long time.
spydutch
#70
Post by spydutch »
For me the Spydies that went through the most cuttings are:
SS Cricket/SE
Delica 3rd generation in full SpyderEdge
Tasman Salt/SE
Chris_Himself
#71
Post by Chris_Himself »
"Quality is not an accident. It's the result of focused intention, earnest effort, intelligent direction, and careful execution." - Front of the mid-year catalog
BAL
#72
Post by BAL »
Military, nuff said.
Onionman
#73
Post by Onionman »
BAL wrote:Military, nuff said.
+1 on that. My SE Military is just great for working out in the yard.
For the office, the Caly 3 CF is my favorite.
The important thing was that I had an onion tied to my belt, which was the style at the time. You couldn't get white onions, because of the war. The only thing you could get was those big yellow ones...
ChapmanPreferred
Post by ChapmanPreferred »
CPM S90V Military. Carried most commonly is my SE CF Cricket.
Work EDC List
BRP: CF Military S90V
BLP: Forum S110V Native
[SIGPIC][/SIGPIC]
akaAK
#75
Post by akaAK »
CE Millie, hands down hardest worker in the group. SE Tasman Salt gets carried in the yard often as well.
gull wing
#76
Post by gull wing »
Although I've carried the Sage I more, the Para I (Early), is the "workhorse". While building my house, it was well used. :cool:
SCARAMOUCHE! :bug-red-white
ValueKnifeLover
#77
Post by ValueKnifeLover »
I must update my previous answer... got a saber grind endura 4 the other day... I am in love with this thing. love the blade width with this grind... This thing feels like it was just made to work hard... so that's what I intend to use it for :) So for a work knife I now say my Endura 4
"Laws that forbid the carrying of arms..disarm only those who are neither inclined nor determined to commit crimes. Such laws make things worse for the assaulted and better for the assailants; they serve rather to encourage than prevent homicides, for an unarmed man may be attacked with greater confidence than an armed one." - Thomas Jefferson quoting Cesare Beccaria
kadinh
#78
Post by kadinh »
1. para 1 pe
2. gayle bradley
You should never have to ask yourself "do i really need another knife?" The answer is obvious...
Scottie3000
#79
Post by Scottie3000 »
If by workhorse, you mean subjected to the most hard use, then it's easy for me! A "regular" S30V PE Millie and a SE Endura ZDP-189. I carried both in Afghanistan for nearly a year. Both saw just about everything including what most would consider abuse and both are still part of my EDC rotation in fine shape aside from a little wear and tear and a few "battle" scars.
On order: Maxamet Native 5
Current pocket hog: S90V Para2
Next up: Something Blurple
Dr. Snubnose
#80
Post by Dr. Snubnose »
When I think workhorse...I can only think of one Spyderco that tops all the rest in my collection...The ChinooK II. If I'm cutting, slashing, sawing, and prying...nothing holds up in the performance category as the Chinook II. For me it's not only a SD knife but a utility tool all wrapped up in one. I once was cutting some tough zip ties and the blade cut through so easy it kept on flying in a direction I didn't want it to go...right into a round cement column.....point first....I was like OMG there goes my point!!! :eek: Not only was the point still intact after-wards, there wasn't a deformation, burr or scratch on that knife....furthermore It took a rather large chuck of the concrete out of the column....amazing.....Doc :D
