Be sure to let us know how the steel performs.
Caly 3.5 Super Blue
Just got mine today and felt the need to echo the impressions that have already been posted. This knife is sweet. Very sharp out of the box and nice smooth action. The gray G10 looks nice as well and will contrast nicely with a patina. I think I'll be using some white vinegar this weekend like mongatu has done.
Can't wait to start carrying and using this thing. :D
After a few days I also rubbed the blade with some fine steel wool to lighten up the patina just a little. It was a more silvery gray when I finished. It also continues to darken and develop more "character" each time I use it on food. Very pleased that there is no sign at all of any rust spots developing.
Peter - My :spyder:'s:
Caly~3.5 (VG-10 & S. Blue); Para2~(20CP~M390~S30v); Military~(M390~S30v); Endura & Delica~4~FFG; Native~(S30v); Caly~Jr.~(ZDP); Manix~2~(M4); Ladybug~3~(VG-10. SE); Mules~(M390).
New batch arrived today at Cutlery Shoppe. Just put mine on order.
Forgot to mention, Jeff has these at 35% off MSRP. Also, look under SPYDERCO SPRINT RUN as it does not appear at this time under "What's New" or the regular "Spyderco" headings.
Is that from grapefruit or vinegar? I like it.eloreno wrote:White balance is off but you get the idea,
I have a question. I reprofiled the blade to a thinner edge yesterday. And I used the same sharpening process I use for my CPM steels. Grit wheel to shape the bevel, and two polish steps, 6 micron compound followed by 2 micron compound. Now the blade feels over polished with very little bite. And yet it slices well.
What sort of adjustments do you guys make for carbon steel blades vs the typical CPM stainless steel blades? Did I over polish and dulled the edge?
Dan (dsmegst)
:spyder:
:spyder:
:spyder:
:spyder:
Polishing doesn't dull edges unless you somehow rounded the edge in the process (which is pretty easy to do).
I sharpen the carbon pretty much the same as I do with other blades. It does seem to polish up to a very brilliant mirror quite quickly and easily and also seems to get very sharp very easily even at the lower grits.
I must have screwed up the angle during a pass. I touched up the edge again when I got home and now the edge is whittling hair. :o All it takes is one bad pass.mongatu wrote:Polishing doesn't dull edges unless you somehow rounded the edge in the process (which is pretty easy to do).
Dan (dsmegst)
:spyder:
:spyder:
:spyder:
:spyder:
WalzAaronFFG
Just placed my order at CS. I was going to get the Chaparral, but once I saw that the price dropped from $146 to $134 I couldn't pass up the deal.
I have no idea why Jeff would take $10 more dollars off of an already great deal, but you won't hear me complaining.
This will be my first experience with Super Blue. I may not do the force patina, but I think I may just let it do its thing naturally. Super excited about this one.... Unfortunately I can't carry it everyday cause of the larger blade
:spyder:Current Spydies:spyder:
Blue Delica 4, Jigged Bone Delica-Orange, G10 Delica, ZDP-189 Delica 4, Tenacious, Caly3 CF, Manix 2 DLC, Para2 Digicam, Sage 3, Sage 1, G-10 Dragonfly, Etched Cricket, Salt, Ladybug ZDP-189, Ladybug White SE, Ladybug Hawkbill Salt, Mule Team 11 - M390 w/ custom kydex sheath
:spyder:En Route:spyder:
Spyderco Navaja
Spyderco Navaja
Makes me wish I had waited and not gotten mine through a pre-order at KC.
I really like the steel and am tempted to pick up another from CS for backup at this great price but I've been so spoiled by the Para 2 that now it's hard for me to get enthused about the Caly platform enough to buy another one beyond the two I already have (1 VG-10 and 1 SB).
Thanks, I went with the grapefruit. If I were to do it again, I would put it in vinegar for a little while and then transfer to the grapefruit.Sequimite wrote:Is that from grapefruit or vinegar? I like it.
I have a BRKT Canadian Special I did this way and it looks awesome.
I'd post a pic but that would be sacrilegious!
