RIT-dyed white spydies -- how are they holding up?
donvito
#161
Post by donvito »
Yellow :spyder: can be dyed Orange, Green, Mud/Golden Brown and Red :D . Ladybug was my first attempt at dyeing yellow frn and didn't come out the right shade of orange, so I redyed it again with red liquid rit dye. Saver Salt was my second attempt and the shade of orange is perfect, I used a combination of yellow and scarlet red liquid rit dye dunking the knife for a less than a minute, rinsing to check on the color and applying more dye as needed. The trick is not to let the knife sit in the dye solution long enough for it to turn black. Green PE Tasman was spoused be be blue, but came out a shade of OD like green :) which I like, and the SE Tasman was planed to be green and after seeing the results on the PE I decided to mix a bunch of different dyes to achieve this Coyotish Brown color which matches my CB webbing and gear pretty well. Salt I and Grey frn UKPK still sporting their original colors.
p.s. Salt I and Saver Salt see regular edc rotation as a pair and while there is some yellow seen in a few spots where the knife gets rubbed or scratched it has been holding up very well. I didn't let the dye sip into this one too deep in order to achieve the right shade of color.
Blue72
#162
Post by Blue72 »
THG wrote:.................... but it doesn't come off at all with water.
actually mine faded after spending half a day in the pool.......maybe it was the chlorine?
THG
#163
Post by THG »
dd61999 wrote:actually mine faded after spending half a day in the pool.......maybe it was the chlorine?
I'm pretty sure it was the chlorine then, yes.
Im not good at sharpening, even with a sharpmaker. How get your blade good can your blade with an edge pro system? - Bladeforums user
Has anyone really been far even as decided to use even go want to do look more like? - Some Online Meme
Blue72
#164
Post by Blue72 »
either way, I don't think its worth dying an h1 knife for the water, unless you do not mind the upkeep of redying the knife
Jmanwit
#165
Post by Jmanwit »
STi wrote:Image
Sorry to bump an older thread, but I got a few questions:
First off, I am glad to say that my Girlfriend is now wanting a knife. Lo- and Behold, I come across this thread when she is around, and she says: "That one."
The hard part is done. Thanks to a generous man on Bladeforums, I have one coming out to me. Now here are the questions:
Should I take it apart before dying, and if so, how?
Does dyeing the handle void the warranty?
and finally, Will her sister be jealous?
Jmanwit
#166
Post by Jmanwit »
Bump... Again?
Bluntrauma
#167
Post by Bluntrauma »
Jmanwit wrote:Sorry to bump an older thread, but I got a few questions:
I can't answer all your questions but yes, her sister will be jealous and no you cannot take the knife apart because it is pinned construction. AS to the warranty I do not know.
Sometimes you gotta kick at the darkness until it bleeds daylight.
AKA: Liveitloud on Blade Forums, USN, EDC, Benchmade forums and basically everywhere but here.
liveit_loud on Ebay.
Jmanwit
#168
Post by Jmanwit »
Ya, that's what I thought.... Drag...
Blue72
#169
Post by Blue72 »
Jmanwit wrote:Ya, that's what I thought.... Drag...
no need to take it apart the dye gets in all the crevices and does no damage to the metal parts as long as you wash it with soap and water after your done
Jmanwit
#170
Post by Jmanwit »
dd61999 wrote:no need to take it apart the dye gets in all the crevices and does no damage to the metal parts as long as you wash it with soap and water after your done
Good to know. Any idea about the warranty?
Jmanwit
#171
Post by Jmanwit »
Well, two good things! I got a NIB White Dragonfly from a great guy on Bladeforums, and now I RIT'd it up! But NOT before I called Spyderco and talked to the Warranty dept. RIT dying DOES NOT void the warranty, as the knife is not taken apart to do it!
Spyharpy
#172
Post by Spyharpy »
I've died many G-10 handles (FG to black) and recently several white FRN to orange. The Delicas and Enduras I took apart (fairly easy to do) and dyed just the handles. In case of the Dragonfly, it was pinned construction so I soaked the entire knife. The dye didnt' stick to the metal and easily washed off.
Below are two Delicas I dyed as well as a Dragonfly (all where white FRN).
Dr. Snubnose
Question bout Tie Dye
#173
Post by Dr. Snubnose »
I have a knife...not a Spyderco...but a Benchmade Mini-Griptian....It is one of those Pink Handled (Molded nylon handle) Breast Cancer Awareness Knife...I was wondering if the light Pink Handle could be dyed. Black might work...but do you think I could turn it red?....and how would I do that?....Anyone with any experience with the Nylon handles on the Benchmade?.....Doc :D
Timbo114
#174
Post by Timbo114 »
I've boiled a few SureFire and Streamlight flashlights in the RIT pot ... I'll certainly dunk a few Spydies very soon.
I'm sure a good soak in boiling red RIT would do the trick on that BM.
Remember.. the darker the color you seek, the longer the soak.
I took my lights out of the boil and into ice cold running tap water immediately - to cure any color bleed.
Lookie here ... these lights were all yellow to start with
Spyharpy ... your Tangerine dragonfly is beautiful!
Jmanwit
#175
Post by Jmanwit »
Why do I always seem to be the one who revives this thread? Lol! Anyone have any idea how Foliage FRN would take to being OD? I figure, it's light enough, should be fine. Anyone tried?
Farmer Brown
#176
Post by Farmer Brown »
Jmanwit wrote:Why do I always seem to be the one who revives this thread?
Allow me to lighten your burden!
1. There is a time and place for everything.
2. Not everybody shares your views.
3. Common sense and basic courtesy gets one far.
4. Know your local laws.
5. "Sheeple" is a bigot's term.
Jeremy_A_Neel
#177
Post by Jeremy_A_Neel »
I want to see if anyone has tried dying natural G10 an amber color, and if it can retain its translucency.
"If you have a difficult task, give it to a lazy person - they will find an easier way to do it." -Hlade's Law
Holland
Post by Holland »
I know this doesn't have anything to do with white dyed frn handles, but thought i would share my experience with dying g10.
I dyed my para2 from grey to redish about 8 months ago and carried it all summer while working construction. The dye has held up pretty good, its faded a lot and the grey is starting to poke out on the edges a bit.
before:
now:
Coulro
#179
Post by Coulro »
Mine looks just like the day I dyed it (~10 months ago)
BrianD
#180
Post by BrianD »
Hey guys, first post here at the spyderco forums. First off sorry to be reviving a year old thread. I have a dfly2 salt yellow and was hoping to dye it "toxic green" if possible. I read on this thread some people toying with the idea of trying to achieve the same lime green starting with yellow, just wondering if anyone has tried. Thanks in advance for any replys.
