Patch, Para's G10
gull wing
Patch, Para's G10
Post by gull wing »
I didn't plan on patching the left over screw holes in the G10, but needed something to do while waiting for blades to return from the hardners. The patches pretty well cover, that is, you have to look hard to notice them. There were a few issues to deal with - color and texture. I could have added die to the epoxi, but instead, filed off some black G10 to make dust, then mixed it in. Matching the texture was just as easy. I used the peelcoat from a piece of textured G10, clamped it to the textured side of the knife and filled in the epoxi from the back side.
Piet.S
Post by Piet.S »
Wel done, mixing dust with epoxy to get the right colour works nice, also with wood.
Fred Sanford
Post by Fred Sanford »
Man that looks nice. Did the older Para's come with a single side pivot screw like yours or did you do that?
Kryosphinx
Post by Kryosphinx »
What screw holes?
Zac
Location: Lutherville, Maryland, USA, Earth, Solar System
Post by Zac »
that looks good...what did you do to it for hardening?
WARNING: Sanity not guaranteed.
jerseybounce_42
Post by jerseybounce_42 »
Nice job. With your skills I wouldn't be surprized if your next feat will be to veneer the handles with something exotic like abelone or mother of pearl.
What kind of epoxy did you use?
Is the epoxy's solvent acetone or alcohol based?
Im Himmel gibt's kein Bier
WTC 1993 was enough for me.
gull wing
Post by gull wing »
Thank you!
1. This Para was an early version with pivot pin heads not flush with scales. To fix: I turned the "fixed" end of the pivot head down to below scale surface (cut down with lathe). The "screw" side i just replaced the #4 screw with a low profile screw. Painted all screws and there you are.
2. I used Davcon two ton epoxy.
3. Inlay mother of pearl, that could be my next challenge.
