«Other» disassembly
«Other» disassembly
0545 very flimsy for a zt
0350, torsion bar was broken
Benchmade 586s mini barrage
Bugout 535
8th_Note
Re: «Other» disassembly
Post by 8th_Note »
Makunochimaster wrote:
Fri Jun 20, 2025 11:35 pm
Bugout 535
Neat thread. I'll try to add some later this week
8th_Note
Post by 8th_Note »
Civivi Elementum.
D2 blade, micarta scales, full skeletonized steel liners, ceramic ball bearings, ceramic detent ball, T8 hardware
8th_Note
Post by 8th_Note »
Benchmade Griptillian
S30V steel, FRN handles, partial liners, axis lock, phosphor bronze washers, T6 hardware, T10 pivot
8th_Note
Post by 8th_Note »
Kizer Banish
This is a small button lock, designed by Justin Lundquist. It has a 2.3" 154CM blade sheepsfoot blade, very nice micarta scales, full steel liners, ceramic ball bearings, T8 hardware and pivot.
8th_Note
Post by 8th_Note »
Kizer Original Serape
154CM drop-point blade that is 3", G10 scales with partial steel liners, button plunge lock, ceramic ball bearings, T6 hardware and T8 pivot
8th_Note
Post by 8th_Note »
CJRB Locust
AR-RPM9 dagger-style blade that is 3.15", G10 and stainless scales, full steel liners, button plunge lock with secondary safety lock, ceramic ball bearings, T8 and T6 hardware with T8 pivot
This thing has a ton of parts. It took 3 hands to re-assemble it
Demko AD20.5
microtech ultratech d/e 2022
zero tolerance 0357
These CRK's are simple and robust. Two of the reasons why I like them so much.
Sebenza 31
Pivot bushing and 2mm hex hardware all around (including a single 2mm hex screw for the clip on all three these models).
Inkosi
Overbuilt pivot, PB washers, and stop pin. No pivot bushing. 1/8" and 2mm hex hardware. No lanyard post.
Umnumzaan
No pivot bushing, no stop pin. 1/8" and 2mm hex hardware. Only one body stand-off when you get rid of the non-structural lanyard post.
Giygas
Post by Giygas »
cold steel american lawman
