Byrd Rust Resistance?
SpyderEdgeForever
Post by SpyderEdgeForever »
Say a person cannot afford a Salt knife so opts for a Byrd instead. How good are they at resisting rust and corrosion?
JohnNYPD
Re: Byrd Rust Resistance?
Post by JohnNYPD »
Excellent. I have carried a Byrd Harrier 2 out on the Atlantic Ocean fishing many times. I just rinse with some soap and warm water at the end of the day. No issues with rust or pitting.
8Cr is less corrosion resistant than a lot of common steels like VG10, S30V, etc. I see spotting on Byrds more easily than Spydercos for this reason.
The black coated Byrds, and S35VN/BD1/BD1N models hold up better.
If you're on a budget I'd watch ebay for pacific salt 1's or salt 1's. You can get them in good shape for $50-75.
Actinolite
Post by Actinolite »
I have four Byrds:
Robin 2 and Hawkbill (8Cr), and Crow 2 and Raven 2 (BD1).
I've never had an issue with the BD1 Byrds. My Hawkbill is used gardening, and I clean the knife after every use. No problems at all; it just works great.
The Robin has had a few rust dots on the blade. I've carried a Lil Native 10V or a Chaparral in that same pocket much more frequently, and neither the tool steel nor the nearly-stainless XHP have had issues.
I do not know what caused the few spots on the Robin 2, and I haven't seen a repeat of it.
Oldest: 1974 Buck 110.
Newest: MagnaMax MT46P & MT46S
PM2Josh
Post by PM2Josh »
I feel pretty confident in using my Byrd for saltwater use, provided I rinse the blade afterward. I usually opt for 91% rubbing alcohol to do this, as it dries really quickly.
Then, I add some spot-on oil to coat the blade and inner liners with a small piece of paper towel to reach the inner liners.
However, a fresh water rinse will suffice, provided you get the excess moisture out. This can be done by wiping down or using a fan.
I have no idea how my liners look on the sides of my FRN scales, as I have never taken them off yet.
But I can tell you this: a Byrd is a **** fine budget-priced pocket knife.
SpyderEdgeForever
Thank you, Josh! This is some of the best knife news I have read.
PM2Josh
Post by PM2Josh »
SpyderEdgeForever wrote:
Wed Sep 10, 2025 10:26 am
Even if you do get some rust on stainless, chances are it will be so minute that you can wipe it off with some Bar Keepers Friend, Comet, or a rust eraser.
Stainless, even cheap stainless, does not just rust like crazy compared to carbon steel.
In my shed, I have an Estwing stainless sportsman hand axe and a bunch of carbon steel tools.
When I looked in the shed after a year of humid heat and cold winter, I noticed my shovel, pick, machete, hoe, etc., which are carbon steel tools, gather rust. Even with a coat of WD-40.
My stainless Estwing hand axe barely had a few tiny spots, which I removed in less than 2 minutes with a small wire brush.
My carbon steel tools now get a coat of clear spray enamel or clear coat every 2 to 12 months, depending on how often I use that tool.
Not one spot of rust ever since..
PM2Josh
Post by PM2Josh »
PM2Josh wrote:
Sat Sep 13, 2025 5:45 pm
(Accidental double post glitch)
SpyderEdgeForever
Wow THANK YOU!
I needed this advice and insight. Thanks, Josh.
This encourages my love for stainless steel and also Byrd knives.
