Then I immediately thought, "That would be even cooler if it was a medium grit Spyderco ceramic."
Anyone else think something like this would be a neat Spyderco product?
Or, just drill a hole through a diamond or CBN rod, run a string, cut to length and done. You could probably get 2-4 per rod depending on length.Evil D wrote: ↑Thu Jul 10, 2025 4:20 amIf you can find someone with a 3D printer they could make you a piece that can fit a Sharpmaker rod that has a ring on the other end to tie a cord to for the necklace, and you can shorten the rod to your liking. You also have 3 ceramic grits and diamond/CBN to choose from.
CBN that and I’m happily in for one. 400 grit
Deffinitely a good trick, but I think there is something fun about having it in necklace format. How do you use the sandpaper when you sharpen something? Do you put it on something flat and sharpen like a bench stone?Stuart Ackerman wrote: ↑Thu Jul 10, 2025 6:29 pmI carry 180 and 240 grit silicon carbide paper in my wallet...one by four inches folded.
Does this work with 15V?Stuart Ackerman wrote: ↑Thu Jul 10, 2025 6:29 pmI carry 180 and 240 grit silicon carbide paper in my wallet...one by four inches folded.
what happens if you rub 15V with sandpaper? if steel gets removed, then there's your answerVandymanG wrote: ↑Thu Jul 10, 2025 11:28 pmDoes this work with 15V?Stuart Ackerman wrote: ↑Thu Jul 10, 2025 6:29 pmI carry 180 and 240 grit silicon carbide paper in my wallet...one by four inches folded.
I have one but it doesn’t work on the harder tool steels. Quit wearing it for that reason week and the stone I got doesn’t look as nice.Scandi Grind wrote: ↑Wed Jul 09, 2025 8:27 pmI saw this Arkansas sharpening stone necklace and thought it was a pretty neat way to carry an emergency/edc/backup sharpener on your person.
RustyIron wrote: ↑Thu Jul 10, 2025 11:16 am
Not being a dog or a slave, I don't wear things around my neck, especially that little dinky trinket that would fit better on a teenage girl's charm bracelet (maybe a goth teenage girl). But if I WAS going to wear a sharpener around my neck, this is how I'd rock it.
