Is a gun lube - protector spray like Gibbs good on Spyderco's
Springfield1903
Post by Springfield1903 »
Titles says is all. What do you think:
"Is a gun lube - protector spray like Gibbs good on Spyderco's"
Thnx
Mike
Danke
Re: Is a gun lube - protector spray like Gibbs good on Spyderco's
Post by Danke »
I've used Fireclean and Breakfree. Some people swear by Froglube.
You don't have to deal with carbon fouling. You just need to resist rust and keep things wetish. Just about any oil that's not super toxic will be OK.
blueblur
Post by blueblur »
I use frog lube to coat a non stainless steel blade if I don’t expect to use it for a while. Geiselle purple go juice is my go to for lubing pivots. Without much braking in, it makes my compression locks drop free and does a pretty good job of getting rid of any initial lock stick.
Springfield1903
Thnx
Mike
VashHash
Post by VashHash »
I use slip2000. No issues yet.
8th_Note
Post by 8th_Note »
Springfield1903 wrote:
Fri Apr 11, 2025 8:46 am
Thnx
Mike
I use Hoppe's Elite for cleaning my knives. Especially when I buy a used knife. It works really well, along with a brass bristle brush, to get old grease and oil off, and it cleans up minor corrosion very well too. I like it because it's virtually odorless. It works good on gunked up G10 or FRN handle scales too.
For lubricating, I use 3-in-1 oil (that's the brand name)
S30V; S35VN; VG-10; BD1N; H1; SuperBlue/SUS410; 8Cr13MoV; Micro-Melt PD#1; REX-45; K390; Magnacut; HAP40/SUS410; 20CV; 15V; M4; SPY27; LC200N; S90V
Meadowlark
Post by Meadowlark »
..a 'lil minril earl don't seem ta hurt much neither
RustyIron
Post by RustyIron »
Sure, Gibbs is fine. So is any other general purpose lubricant that you might use on guns or other small mechanisms. We're working on knives, not Swiss watches. As long as you don't get absurd with grease, heavy motor oil, or vegetable oil from the kitchen, you'll do great.
Danke
Post by Danke »
Oil advice from a guy named "Rusty Iron"?
apollo
Post by apollo »
I use Balistol for protection and nano oil for the pivot with good results but i do not use my Spydies to prepare food.
Scandi Grind
Post by Scandi Grind »
Yeah, most gun lubes are the right type of thing for knife pivots as well. Personally I like to use things that are less chemically on knives than what I might use on some guns, so I like to go with something like Ballistol or even just mineral oil has been fine.
-- Old Norse proverb
Clay H
Post by Clay H »
My favorite products for my knives are Rem Oil spray, Boeing T-9 Boeshield, and Corrosion-X. I'm also happy to use WD-40 if that's what is available.
cabfrank
Post by cabfrank »
Ballistol. It's food safe in case you cut something to eat. It works great.
RustyIron
Post by RustyIron »
Danke wrote:
Sat Apr 12, 2025 9:22 am
:zany
Well, I do like my patination.
Slash
Post by Slash »
Sure. Why not. Anything is better than nothing...
Springfield1903
Haha
Lol
Thank everyone for chiming in-um going with frog lube on one :-)
Mike
Blerv
Post by Blerv »
I have some Frog Lube which is ok and smells great. I’d probably lean to mineral oil as a wipe down.
Unless you really need corrosion protection my issue is the smell with the more caustic chemical. I haven’t used Gibbs so IMHO it comes down to the protection needed for the side affects you get.
