You got your Ceramic Mule. How you gonna sharpen it?
Steeltoez83
Re: You got your Ceramic Mule. How you gonna sharpen it?
#161
Post by Steeltoez83 »
I have my own criticisms of why this was made too. I wasn't wearing my excited pants when the ball started rolling either. I'm moving thru these shenanigans of mine to really see what this stuff can do. So far I haven't thought of a practical use for it yet. However I have seen edge retention improvements thru sharpening. I am working my way thru harder materials such as ice right now, and limestone after that. Spyderco likes to take the road less traveled, those usually have the most stones.
I don't want to detour from my normal testing too much. Bridging off test results and making gradual alterations is helping me identify where the rubber meets the road. Instead of 60% in 1 day, extend it over 7 to get a percentage not a pass or fail score. Then replicate the same amount of impacts the ice got, but with a harder material like limestone. Depending on the damage or lack of, move up to a cinderblock same idea. The process is gradual, but I'm hoping to provide a few more positive points to the discussions.
hewn7
#162
Post by hewn7 »
burlyspyder wrote:
Sat Apr 27, 2024 5:27 am
hewn7 wrote:
Tue Apr 23, 2024 5:53 pm
I too would like a broken piece for SEM if anyone has any to spare. It doesn't need to be as small as Hewn's.
Hewn, what model do you have?
We have a phenom, It can take samples larger than that but that’s the size of the “sticky tiles” we have to mount samples on.
I do have a 20 micron diamond film belt on the way. I’ll try that with lubricant on the 2x72 running slowing in reverse on a rubber wheel and see what we get.
Have been using the mules around the house, kitchen, barn and they have been great. No chips etc, but I do tend to be careful with my blades. Save for last weekend when I was cutting a piece of rubber edging with my umnumzaan. Dang thing had a strip of metal
In it. 🤨
burlyspyder
#163
Post by burlyspyder »
hewn7 wrote:
Fri May 03, 2024 1:22 pm
Nice, we also have a Phenom. I figured as long as it can fit in the tray I'd be able to figure it out. The reason I asked is because you described the mount area for samples almost exactly. I haven't run anything ceramic, will be interesting if I can get a piece. Maybe I will try sputter coating as well for giggles.
:bug-red: H1, M4, 4v, 10v, Hap40, s90v, s110v, Rex-121, BD1n, Maxamet, Magnacut
MT; Z-max, Z-wear, Magnacut, SRS13, Rex76, M398, T15, K294, ZDP-189, HIC, AEB-L, SPY27, 15v
Other: D2, White#1, Blue#2, SuperBlue, VG-10, 204P, 20cv, s30v, s35vn, s45vn, s90v, HIC, TC71
hewn7
#164
Post by hewn7 »
I think it would be interesting to see grain size and what’s happening to the grains along the edge. Usually to see grain boundaries you need to etch a material fist,
But I’m not sure what that would be done with for this material.
I did sharpen on mule with the diamond film belt this weekend with water as a lubricant. It’s around the same sharpness as the tormek w cbn mule now, but with a finer smoother edge. On a 3 Finger test it feels sharper but shaving and papertowl say it’s around the same.
Still using the knives daily and they work great around the house. Have a Bahamas trip coming up so I’ll take 2 there and use them as for diving, rigging, fish cleaning etc.
Nottoby
#165
Post by Nottoby »
Got my hic mule not real sharp but i knew it was gping to be a little rough it cut paper but not to well decided to try yo sharpen it a little i have watched lots of vids on utube on sharpening ceramic knives most of it is hands on but i have. Learned that thesharpening method must be fine so i worked on it alittle and that works just fine 3000 grit diamons polish it just fine Let you know progess
Nottoby
Sharpening ceramic mule
#166
Post by Nottoby »
I have been trying to get an edge on a ceramic mule . I have been finding that a fine grit diamond works very well to polish edge . With no chipping . I have one chip but it was there bran new.the diamonds i use are 2000 and 3000 . Any thoughts thanks
bloggablu
#167
Post by bloggablu »
I'm not sure if anyone's mentioned this already or not but if you watch outdoors55 on YouTube the only way he could properly sharpen ceramic was taking a wooden wheel and using diamond paste as the abrasive so it wouldn't chip the blade if I recall, since every other method chipped the edge. That's the method I would use. Every time I've tried to sharpen one with a diamond sharpener no matter the grit size it usually always chips.
Giygas
#168
Post by Giygas »
Todd, at Science of Sharp just posted a great article about the HIC Mule!
https://scienceofsharp.com/2024/09/04/h ... t-ceramic/
VandymanG
#169
Post by VandymanG »
Haven’t tried to sharpen mine cause it slices through fruits and vegetables with ease. I don’t envision ever carrying this as an edc so I use it for what suits me best, food prep.
Greg
MNOSD member #0054
* EDC - PM2 CPM S45VN G10 all black, LeafJumper SE K390
hewn7
#170
Post by hewn7 »
Just getting back from an elk hunting trip. I used the HIC mule to cape and bone out some, but not all, of my bull. Had it shaving sharp off resin bonded diamond stones (up to 6k JIS) before stropping it. Overall it did well, still scrape shaves at the front 1/3 of the blade which would've seen the most work. I can feel a few small chips in the apex when running my fingernail along it but they are not large enough to be visible. I did chip off the very tip at an odd angle so that there is still a very usable point but it's a very slight drop point there now. I believe I did that by hitting it on a stainless table when boning out a rear quarter. Will sharpen it back up and carry on, but so far no major issues.
#171
Giygas wrote:
Wed Sep 04, 2024 11:10 am
Thanks for this ^
attila
#172
Post by attila »
I sharpened mine with the Hapstone and Venev resin bonded stones. It was slow-going, and I haven’t achieved shaving sharp yet, but it cuts really well compared to the rolled/dull “cutting edge” nonsense that the factory sent mine with. Patience is key.
I did manage to damage the edge pretty badly today about 1/2” from the kick as I ground down the annoying nub. I intend to sharpen that small section and blend the thicker BTE (estimated 0.026”-0.030”) near the handle with the rest of the edge (~0.022”) instead of reprofiling the whole length of the edge. I hope it isn’t too visually off putting.
Want: SPY27, K490, Swick 5
Rusel2009
#173
Post by Rusel2009 »
Has anyone tried to run one of these through a metal detector?
Michael Janich
#174
Post by Michael Janich »
Dear Rusel2009:
Stay safe,
Mike
VandymanG
#175
Post by VandymanG »
Rusel2009 wrote:
Thu Feb 13, 2025 7:42 pm
Not worth losing one of the more expensive mules or the possible legal issues that could result. I tend to avoid things that are going to result in a felony, jail and or hefty legal fines.
Greg
MNOSD member #0054
wmcbride
#176
Post by wmcbride »
I ordered a two sided leather strop that comes with 7 micron and 1.5 micron diamond emulsion for about $50 to my door and was able to get the HIC mule shaving sharp in a few minutes.
Barring significant edge damage I think this is the way to go for me as it’s cheap, simple, and compact.
If I pick up any big dings I will reprofile the edge with the diamond rods for the sharpmaker, which I already have.
JestersHK
#177
Post by JestersHK »
I've been through 2 different metal detectors with mine. Also had it in the Kydex sheath.
baldanthony
#178
Post by baldanthony »
Heyo! Unsure if it's better to keep upkeep for HIC in this topic or start a new one... so forgive my etiquette here if I made the wrong decision.
What kind of upkeep should we consider for this one? Ceramics don't require oil, but is there any special way to clean it or coating before storing it?
Gonna try my hand at sharpening soon, I have this, Terravantium, dendritic cobalt and REX121 waiting on me getting the right material to sharpen lol
Cheers!
