Initial Impressions of the New Proto Cut
Phil Wilson
Location: Northern California in the heart of the Gold Country
Post by Phil Wilson »
I am calling it Proto Cut until It gets an official name
I got some sample to work with and have done several blades through final heat treat and just short of a working knife to do some field testing. A new grade like this one needs to be friendly to work with and that is what I was looking for. The sample was initial ground so there was no scale to worry about. Profile and rough bevel grinding with a 50 grit belt went nice and easy, same as Magna Cut for example. The sample came with a simple data sheet and so without the foundry details I used my sequence for CPM S90V.
Pre heat and Austentize @ 2140, hold for 20 minutes
Plate quench down to room temperature
Direct to LN2. Hold for 4 hours
Temper @ 300 to 450 F for 1 hour 3 times aiming for a final aim result of 63 to start with.
I did 2 long thin fillet knives and saw no tendency for warpage.
Upon final grind I will be tuning for toughness, corrosion resistance and edge holding balance. I can compare my results with the final detailed foundry data sheet and Larrin's CATRA and impact toughness information that will be coming as the grade is officially introduced.I know this is more information than some on this forum who just want to buy the knife and use it. The objective is to provide a starting point on the usability and workability for both custom makers and larger makers who will be trying and testing this photo type grade. I would say this is "user, maker" friendly and is pretty much the same in that category as its Magna Cut relative.
Phil
Re: Initial Impressions of the New Proto Cut
Hi Phil,
Thanx much for chiming in. I'm looking forward to your thoughts on this.
We've done a lot of testing in Golden, which is ongoing. I'm using a Mule every day for kitchen and general cutting. So far it's been quite impressive. We've done Corrosion tests in Golden, but Eric is now planning to do some Real World Testing in Salt Water.
Thanx much to Larrin for another well thought out blade steel,.
Mk-211
Post by Mk-211 »
Wasn't the nickname MagnaTuff?
Enactive
Post by Enactive »
Mk-211 wrote:
Sun Dec 22, 2024 1:55 pm
In this case, I'd defer to Phil. :cheap-sunglasses
Mk-211
Post by Mk-211 »
I defer to this thread, page 6.
viewtopic.php?t=97308
Bradford knives made the comment, calling it MagnaTuff
They're both, admittedly, made up names - it's not something to get hung up on right now...
Enactive
Post by Enactive »
its all funsies until the trade name appears for real.
Mk-211
Post by Mk-211 »
At this rate, Dr. Thomas might have to have a poll, for the best name. 😆
p_atrick
Post by p_atrick »
Mk-211 wrote:
Sun Dec 22, 2024 2:49 pm
Steely McSteelface
Synov
Post by Synov »
*cough cough*
S90V: Nirvana Military 2 CF Native 5 Fluted CF Manix XL CF Yojumbo CF Shaman CF Sage 6 CF CPM-154/S90V: Manix 2 CF 15V: PM2 Marble CF 4V: Manix 2 Marble CF 3V: Tuff REX 121: Sage 5 CF 20CV: Subvert CF ZDP-189: Dragonfly 2 Nishijin S30V: Sage 4 Damasteel: Native 5 40th Anniversary VG-10: Delica 25th Anniversary N690Co: PITS XHP: Chaparral Birdseye Maple MagnaCut: Native 5 Fluted Ti PM2 Crucible
Wandering_About
Post by Wandering_About »
Looking forward to Phil's continued reports on this steel!
MNOSD member #0035
Larrin
Post by Larrin »
Thanks Phil!
msum
Post by msum »
Does the Crucible situation have any bearing on the prototyping and the eventual (hopefully) production?
Does it mean it won’t necessarily end up as a CPM steel but another foundry might produce it?
Cycletroll
Post by Cycletroll »
Thank you Phil! I for one appreciate the benefit of your experience.
msum wrote:
Sun Dec 22, 2024 6:50 pm
Hi Msum,
That's what we're all waiting to find out?
Great info and thread, thanks Phil! Looking forward to your developments.
Post by Doc Dan »
As more information comes in, it would be nice to have it updated here.
gooeytek
Post by gooeytek »
Phil Wilson wrote:
Sun Dec 22, 2024 1:21 pm
Phil
Seamount Knifeworks has spoken. If Phil likes it, I want it. That said, Phil's part of the reason why S90V is my preferred steel. :grin-big eyes
Ti junkie. Steel snob. Voids warranties.
Phil Wilson
Thanks Sal and all
The workability of a new steel is important given some history of earlier grades during initial introduction. CPM S90V (420V) for example was a bit stubborn in heat treat due to the high vanadium content. It has now been tweaked for a good snappy response. Others like CPM S30v took a few years to optimize the heat treat as we remember. This new prototype has good response and should be easy to match up to individual equipment for the best result. It will be optimized by Shawn (BBB) for example to get the very most out of it for his design conditions. We will wait for Larrin's CATRA and toughness data for more precise measurement of performance and balance and where it fits into the amazing list of steels we now have to work with. I look forward to cutting a bunch of rope, using it in the kitchen and hopefully fillet some salmon with it. Thanks to Dr Larrin for your work and science based knife steel information.
Phil
p_atrick
Post by p_atrick »
The emphasis placed on workability is not surprising. This is from Larrin's conclusion about M398:
I’m personally not all that interested in yet another high edge retention steel that sacrifices toughness, ease in sharpening, and workability.
