Para Military 2 Black Rex 76 Brick Dark Gray G10
10am CENTRAL TIME on Black Friday, November the 29th. Online Only. Limit 2 per customer.
https://www.gpknives.com/spyderco-para- ... y-g10.html
- thuyenbuom
Re: Para Military 2 Black Rex 76 Brick Dark Gray G10
Mrj, thank you for the availability info. I hope to get one.
Necromonger: What do you think of this blade?
Riddick: I think it is a half gram heavy on the back end.
The Chronicles of Riddick - Blade Scene
- WilliamMunny
Good looking knife, especially with the different scales texture.
- Manixguy@1994
Mrj , the PM2 is very tempting . I must be strong !
Dan
I am weak brother. Very weak.Manixguy@1994 wrote: ↑Thu Nov 21, 2024 6:09 pmMrj , the PM2 is very tempting . I must be strong !Dan
- Steeltoez83
Definitely gonna try to get 1. Rex 76 has been my favorite mule team steel.
I've been on a PM2 kick lately and I've been carrying and using some of mine a lot. I think the brick pattern scales look cool but I have this feeling they'll be pocket shredders even more than peel-ply G10. I think I'll sit this one out but I'll be looking forward to hearing what you guys think of it
Fantastic. That's something new, unseen and unexpected. But in a good way. Never thought I would see rex76 making it in a production folder. I mean, usually those new steels come as sprint runs first and after that dealer exclusives. This time around Gpknives cought me off guard. And since there won't be online seconds sale, I'm in for two of these. User and a backup. I'm not sure how is it going to be, but I have feeling this particular one is going to fly off the shelves. Best of luck everyone.
Yeah but “Weak things break!” MrReacherMrj wrote: ↑Thu Nov 21, 2024 6:10 pmI am weak brother. Very weak.Manixguy@1994 wrote: ↑Thu Nov 21, 2024 6:09 pmMrj , the PM2 is very tempting . I must be strong !Dan
SaltyCaribbeanDfly wrote: ↑Fri Nov 22, 2024 3:51 amYeah but “Weak things break!” MrReacherMrj wrote: ↑Thu Nov 21, 2024 6:10 pmI am weak brother. Very weak.Manixguy@1994 wrote: ↑Thu Nov 21, 2024 6:09 pmMrj , the PM2 is very tempting . I must be strong !Dan
I don't know much about this steel. Larrin's testing from 2021 suggests it's similar to REX 45 but can be run a couple points harder, pushing it towards a little more wear resistance and a little less toughness.
https://knifesteelnerds.com/2021/05/10/ ... 15-rex-76/
Are there any other tests or in-use reviews floating around for this steel?
MNOSD #0051
- Steeltoez83
I did different style testing when I had the mules in my possession. My mules tested 69.3 hrc. And in the testing I was doing, rex 76 was out performing everything I was testing it against. I think k390 and cruwear were the only steels keeping up.
I assume a non dlc version is on its way as well?
If only there was a Para 3 in this pattern. Though I may get as well. I am a sucker for black and grey.
@Enactive been there before. All good
Hope we see more milled scales out of Golden. I think that is awesome!
