Can the Opening Hole be improved?
- SpyderEdgeForever
Can the trademarked Spyderco Opening Hole be improved or have all known methods been tried and it is perfect ?
Someone suggested Spyderco mill the inner hole to give it better grip rather than make it smooth.
Re: Can the Opening Hole be improved?
No need to fix something that ain't broke.
Who suggested this? Maybe they can explain why.SpyderEdgeForever wrote: ↑Mon Aug 19, 2024 9:44 pmSomeone suggested Spyderco mill the inner hole to give it better grip rather than make it smooth.
Yes. Countersink at 45 degrees
Mule Team Army 001 (patched)
MNOSD 008
Stable Mules; Z-Max, Z-Wear, Magna Cut, Magna Max, SRS13, Rex 76, Rex T15.
MNOSD 008
Stable Mules; Z-Max, Z-Wear, Magna Cut, Magna Max, SRS13, Rex 76, Rex T15.Re: Can the Opening Hole be improved?
"BILL: This is called a Scrumdidilyumptious Bar.
WINKELMANN: Scrumbibilyunctious Bar? How does he do it?
BILL: My dear boy, do you ask a fish how it swims?
WINKELMANN: No . . .
BILL: Or a bird how it flies?
BILL: No sirree, you don't! They do it because they were born to do it. Just like Willy Wonka was born to be a candy man, you look like you were born to be a Wonkarer."
You can't improve on perfection.
- mark greenman
I think the opening hole could be 'supplemented' via the ATR 'cobra hood'. This provides a secondary / backup method of opening should your thumb not fully engage the thumb hole, and also provides a much more comfortable thumb rest when using the knife.
I think it would be cool to see these offered as an aftermarket/spyderco option for adding to some of Spydercos most popular models, thats secured with set screws pressing along the side of the blade as a friction fit.
Cobrahood + Wave option I think would also be popular as a bolt on addition.
- Paul Ardbeg
Never thought about this as it works very well for me on all models, small, large, backlock, RIL, CBBL, linerlock, comp lock, etc, etc.
Just don't suggest getting rid of the spydie hole. You would break the internet, and all the spydie employees couldn't put it back together
I take a Dremel to all of mine that aren't DLC, cleaning up any machine marks inside the hole and sharpening the edge so it's nice and crisp.
My favorite opening hole is this one:
Chamfering and widening the hole does improve flickability, but is it worth changing Spyderco's signature design?
S90V: Nirvana Military 2 CF Native 5 Fluted CF Manix XL CF Yojumbo CF Shaman CF Sage 6 CF Native Chief CF MagnaCut: Native 5 Fluted Ti PM2 Crucible CPM-154/S90V: Manix 2 CF 15V: PM2 Marble CF 4V: Manix 2 Marble CF 3V: Tuff REX 121: Sage 5 CF 20CV: Subvert CF ZDP-189: Dragonfly 2 Nishijin S30V: Sage 4 Damasteel: Native 5 40th Anniversary VG-10: Delica 25th Anniversary N690Co: PITS XHP: Chaparral Birdseye Maple
Tristan_david2001
I can’t see how the tictac opening hole works better than the perfect circle opening hole. Definitely not as functional. but for fidgety pocket jewelry knives ig it doesn’t matter.
Right?? Always turns into an interesting answer. He talks to more people than I could ever imagine!zhyla wrote: ↑Mon Aug 19, 2024 10:01 pmWho suggested this? Maybe they can explain why.SpyderEdgeForever wrote: ↑Mon Aug 19, 2024 9:44 pmSomeone suggested Spyderco mill the inner hole to give it better grip rather than make it smooth.
I've got to agree with Jim on the topic though...if it ain't broke, don't fix it!
N. Brian Huegel
Perfection through Simplicity. If you want to gain Sal's insight into his innovation you might want to read:
search.php?st=0&sk=t&sd=d&sr=posts&keyw ... thor_id=21
nb
nb
I wouldn’t want a rough opening hole. As you open the knife the skin on your thumb is rotated against the edge of the hole. A rough perimeter would cut into that skin like a serrated edge. I want a smooth hole, sharp enough to grab the finger pad but not sharp enough to slice into it.
If it ain't broke it hasn't been improved enough yet.TkoK83Spy wrote: ↑Tue Aug 20, 2024 7:26 amRight?? Always turns into an interesting answer. He talks to more people than I could ever imagine!zhyla wrote: ↑Mon Aug 19, 2024 10:01 pmSpyderEdgeForever wrote: ↑Mon Aug 19, 2024 9:44 pmSomeone suggested Spyderco mill the inner hole to give it better grip rather than make it smooth.
Wandering_About
I'll say it again, don't fix what isn't broken.
MNOSD member #0035
MNOSD member #0035
Maybe… on a few knives. From a personal aesthetic point of view, I could live with a slightly smaller hole and less ‘hump’ on a few models.
Still plays with knives…
- SpyderJunky
Hear, hear.Bill1170 wrote: ↑Tue Aug 20, 2024 7:49 amI wouldn’t want a rough opening hole. As you open the knife the skin on your thumb is rotated against the edge of the hole. A rough perimeter would cut into that skin like a serrated edge. I want a smooth hole, sharp enough to grab the finger pad but not sharp enough to slice into it.
More area to catch your finger. You can't fail a reverse flick with that design.Tristan_david2001 wrote: ↑Tue Aug 20, 2024 6:42 amI can’t see how the tictac opening hole works better than the perfect circle opening hole. Definitely not as functional. but for fidgety pocket jewelry knives ig it doesn’t matter.
It ain't all about flicking...Synov wrote: ↑Tue Aug 20, 2024 11:32 amMore area to catch your finger. You can't fail a reverse flick with that design.Tristan_david2001 wrote: ↑Tue Aug 20, 2024 6:42 amI can’t see how the tictac opening hole works better than the perfect circle opening hole. Definitely not as functional. but for fidgety pocket jewelry knives ig it doesn’t matter.
