Show your mods!
Drubieg
Re: Show your mods!
#3321
Post by Drubieg »
What do you think of this bladeshape? Thinking of regrinding this 20cv Endura…
Pacu0420
Re: Show your mods!
#3322
Post by Pacu0420 »
Drubieg wrote:
Tue Apr 11, 2023 8:15 pm
What do you think of this bladeshape? Thinking of regrinding this 20cv Endura…0EF145BF-995C-48C7-BF68-6F036F8B0DA3.jpeg2767776E-7584-438A-90FF-5ABAB8D4FE97.jpeg
I love the shape you've got drawn there. Don't know if I'd have the guts to actually do it. Maybe I would if it was a cheap knife I don't care about.
If you do it, post pics!
Drubieg
Re: Show your mods!
#3323
Post by Drubieg »
I will, I’m gunna do it. I’m gunna change it slightly and make it as close to the centofante blade shape as possible
Josh Crutchley
Re: Show your mods!
#3324
Post by Josh Crutchley »
Gotta go thin to win!! Started out thinning with diamond plates but it didn't look that good. Took it to the old 1x30 today and I must say it looks a lot better. Might go a little thinner, right now it's around 0.012" bte.
Laser thin reground CRKT Spew. Can't really measure bte but it's about 0.006" 1mm from the apex. Not good for much other than pure slicing.
Jurmuscle
Re: Show your mods!
#3325
Post by Jurmuscle »
Before and after.
:usflag :bug-red :bug-white-red :usflag
If we spent as much time trying as we do doubting, we might have already accomplished it.
-Tom
Re: Show your mods!
#3326
Looks fantastic Tom ! Good job . Buddy Dan
Jurmuscle
Re: Show your mods!
#3327
Post by Jurmuscle »
Mon Apr 17, 2023 10:28 pm
Thanks Dan. I appreciate it.
-Tom
Senfkarte
Re: Show your mods!
#3328
Post by Senfkarte »
hereiamu1 wrote:
Fri Feb 24, 2023 9:13 pm
Still can't decide, if this is amazing or awful. Kind of the best of both worlds. If there is such a thing.
Amon81
Re: Show your mods!
#3329
Post by Amon81 »
I modded my PM2. Not a massive mod, more for more comfort in use and the fact I like micartia.
After taking it apart I polished the washers with some P7000
Just a Flytanium set, titanium backspacer and titanium clip.
Now just need to sharpen it as its got the factory edge still.
Senfkarte
Re: Show your mods!
#3330
Post by Senfkarte »
Hardly a mod, but more of a personal test.
The clip from the CPM-15V Manix 2.
Stock and shiny:
Stonewashed and more fitting to the blade finish. Not 100% the same, but better than original:
Pacu0420
Re: Show your mods!
#3331
Post by Pacu0420 »
This was my first Spyderco, purchased about 2 years ago. Now I have 10 Spydies and the Para3 got moved to the back burner. Just recently I put the Flytanium scales and hardware on it with a LynchNW clip. Then did the lightning anodization. (Surprisingly easy to do) Now it's my favorite knife in my collection.
Re: Show your mods!
#3332
Wow! You did that yourself? That is really cool.
Pacu0420
Re: Show your mods!
#3333
Post by Pacu0420 »
JSumm wrote:
Thu May 11, 2023 7:11 pm
Thanks, I just recently learned how to do it. It's actually a pretty simple process. There are some good videos on YouTube that walk you through it.
Re: Show your mods!
#3334
Ferric chloride blackwash
Re: Show your mods!
#3335
bearrowland
Re: Show your mods!
#3336
Post by bearrowland »
I like that!
Barry
Bonne Journey!
MNOSD member 0032
jmj3esq
Re: Show your mods!
#3337
Post by jmj3esq »
Re: Show your mods!
#3338
Here is a mod if you don't want to spend money on those silly aftermarket lanyard tubes for the PM2...
I swapped to RGT ti scales for a M4 PM2, and discovered the flared lanyard tube does not fit into the ti scales. Instead of mangling the OEM tube, or getting an aftermarket tube, I modified the scales to fit the flared tube.
Flared ends
A hair under 8mm
The lanyard hole in the liners are slightly over 8mm
The flared tube did not fit in the RGT ti scales, so I enlarged them by about 0.3mm to 8mm.
Another option if you work with G10 or CF is to enlarge the hole slightly using a round dowel wrapped in sandpaper.
Perfect fit, no rattles.
The additional 25g is not excessive, and makes it feel more substantial than a G10 PM2.
I like the end result! 🍻
rrmiles
Re: Show your mods!
#3339
Post by rrmiles »
Is hand engraving considered a mod?
Ramonade
Re: Show your mods!
#3340
Post by Ramonade »
rrmiles wrote:
Fri Jul 14, 2023 1:41 pm
Any visible modification counts IMHO. Beautiful engraving ! The proportions are really good, I would love to learn such an art, I suck at drawing but I'd still like to try :squinting-tongue
Here's all (if I haven't forgotten any) of the scales I made since I started in April. I sometimes made more on order, most of them are for me.
In chronological order, starting with the Chokwe :
