3d printed sheath project
Araignee
Re: 3d printed sheath project
Post by Araignee »
You could possibly add a hole at the tip, after the tenon. That'd mean slightly extending the tip in order to accomdate the hole.
Fireman
Post by Fireman »
by the finger choil, thumb ramp or the belt clip
Mule Team Army 001 (patched)
MNOSD 008 :usflag
Josh Crutchley
Post by Josh Crutchley »
Araignee wrote:
Fri Feb 04, 2022 2:16 am
Fireman wrote:by the finger choil, thumb ramp or the belt clip
I'm trying on the tip first, how's this look?
Fireman
Post by Fireman »
That position would work
The longer distance from the rear of the knife butt where the lanyard would likely be attached could be an issue based on use and storage. The shorter the distance the better imho and another means of retention if a shock cord is used.
MNOSD 008 :usflag
Josh Crutchley
Fireman wrote:
Mon Feb 07, 2022 6:07 pm
I've not settled on where to put the lanyard yet. I might need to add a secondary retention near the nub.
JRinFL
Post by JRinFL »
I’m impressed with how this is turning out.
Josh Crutchley
JRinFL wrote:
Tue Feb 08, 2022 6:40 pm
I want to add patterns that match the different scales I've made. The lanyard is going to move and some other changes may happen. The retention mechanism needs some changes. The part that actually goes in the Spydiehole will need to be made from a harder/tougher material and bonded/glued to the sheath. I'm also thinking of adding pieces of o-rings(source of round rubber) for something to prevent edge damage during insertion.
Josh Crutchley
Fireman
Post by Fireman »
A thought…
one side could be the catch that encapsulates both the thumb ramp and the nub. Probably half of the length would need to have cuts on both sides and printed so it has to bend to sheath side and it would snap over the two sides. If the lanyard hole was on the thumb ramp you could grip the handle, pushing it to the side and forward to let it drop off and be retained by the lanyard attached to the butt.
MNOSD 008 :usflag
Cadenno
Post by Cadenno »
On tingiverse there is a project already made for a case with a double block. (Not my project).
The locking system works reasonably well, there is only one problem, the blade wobbles a lot inside. But maybe starting from that project, you can improve it, and maybe add a clip and a hole for the lanyard.
https://www.thingiverse.com/thing:5228344
PStone
Post by PStone »
Wow Josh! You have some incredible visions that you are making reality. Very quickly too! I am very impressed with your ability to problem solve and improve your designs in real time. As well as taking everyone's suggestions and critiques and incorporating them into your work. Can't wait to see what you make into reality next!
Josh Crutchley
#32
Cadenno wrote:
Wed Feb 09, 2022 3:30 am
That's an issue I'm dealing with as well. I'm using ridges that try to hold the blade but they need a lot of tweaking. Also thinking of using rubber to help secure it better.
Cadenno
#33
Post by Cadenno »
If you want I can do some tests, covering with a layer of elastic resin the ridges to hold the blade in place in your project.
Just brush and then cure with UV, repeating this a few times will create several layers attached directly to the print without gluing other parts.
With the same process I can put a high abrasion resistant resin on the part that comes in contact with the spydiehole.
Araignee
#34
Post by Araignee »
Joshcrutchley1 wrote:
Mon Feb 07, 2022 8:56 am
Nice ! But you've actually inserted two wholes ?
Also, I see that you've enlarged the tenons as well.
And it got me thinking - for a derivative of this design : would a provision for a clip, on the larger end of the sheath, make sense ?
I'm trying to imagine using a standard Spyderco clip, bolting it on the sheath, and then clipping the sheath on a pants pocket.
The knife could then be removed from the sheath using just one hand, with a finger triggering the retention mechanism.
(Given this mechanism isn't ambidextrous, there could be two versions of the "clip sheath" - on for carry on the left hand side, the other for the right hand side).
Josh Crutchley
#35
Araignee wrote:
Thu Feb 10, 2022 4:57 am
Its a drain hole, not sure its needed just seen it on many other designs. The round tenons resulted in thin wall sections that my printer cant handle.
Paraguy
#36
Post by Paraguy »
"Some call me...Tim?"
Araignee
#37
Post by Araignee »
Thu Feb 10, 2022 3:33 pm
Ah I see. But perhaps it's be more efficient to have a few smaller drain holes scattered beneath the blade, rather than just a bigger one at the tip :thinking
The larger tenons makes even more sense given the heterogeneity of printers. This changes should make it easier to print for other people, too 👍
FullScaler
#38
Post by FullScaler »
I am really digging your progress Josh. I am very interested to see the finished product. I can envision matching scales and sheath in the same translucent colors allowing to see the blade through the sheath, and the tang through the scales. And if the sheath and scales both had the same texture (Mule cubes) it would be super sweet.
Https://BladeProtection.com
Josh Crutchley
#39
FullScaler wrote:
Thu Feb 10, 2022 11:40 pm
New version without Spydiehole retention. Replaced with retention at the thumb ramp and the lanyard adds secondary retention at the nub. Going to try an print as one piece.
Fireman
#40
Post by Fireman »
Looking good!
MNOSD 008 :usflag
