I recently purchased a PITS. I relubricated it with mineral oil, but after doing so I realized a small dab of grease has been placed right into the detent on the blade, and might have been serving an important function. I know there is a high load between the titanium handle and blade on that point, as it is right where the blade fits into the titanium standoff. I was wondering if I should get some thicker grease and place some there, If so, what grease would you recommend? Here's the detent:
https://imgur.com/a/kcjqIUl
Caring for Spyderco PITS
Re: Caring for Spyderco PITS
I would try some Sentry Tuf Hi Slip Grease.noeps wrote: ↑Fri Jan 31, 2020 12:08 pmI recently purchased a PITS. I relubricated it with mineral oil, but after doing so I realized a small dab of grease has been placed right into the detent on the blade, and might have been serving an important function. I know there is a high load between the titanium handle and blade on that point, as it is right where the blade fits into the titanium standoff. I was wondering if I should get some thicker grease and place some there, If so, what grease would you recommend? Here's the detent:
The sword the body wounds, sharp words the mind.
- Menander :spyder:
- Menander :spyder:
- Brock O Lee
3-in-1 oil works for me. :)
I find the PITS to be very easy to care for. It is very stainless and the action is very smooth. Sharpens easily too.
- curlyhairedboy
Hmm, I didn't think the standoffs on the PITS were titanium.
Accutronman
Knife Pivot Lube - Thick version
