I just cut myself...
neuronic
Post by neuronic »
...on my Spydiechef... closed :confused:
Pelagic
Re: I just cut myself...
Post by Pelagic »
Explain??? Hopefully it's not bad!
Pancake wrote:
Wed Aug 14, 2019 10:20 pm
Are you a magician? :eek:
Nate wrote:
Thu Apr 04, 2019 4:32 pm
Doeswhateveraspidercan wrote:
Sat Jun 15, 2019 9:17 pm
You are a nobody got it?
neuronic
Post by neuronic »
No idea... was watching something on YT, fidgeting... had to click on something so I held it in my left hand, closed... then I noticed it hurts, looked, et voila... blood - small clean cut on my left index finger.
Not really bad, stopped bleedin after 1 min... but it was closed :confused:
Post by Doc Dan »
Is the cutting edge showing through the cut out for the lock tab, as on some other models?
JonLeBlanc
Post by JonLeBlanc »
Bizarre, I don't doubt that it's at all possible to cut oneself on a Spyderco (I mean they ARE matter separators), I've just never been cut...yet lol. Is there anything about the Spydiechef that could be dangerous when closed? e.g. a weak detent that might allow the blade to swing open ever so slightly, allowing a bit of edge to be exposed? Or something like that? I'm interested to hear Neuronic !
ugaarguy
Post by ugaarguy »
On the Spydiechef, when closed, the edge at the heel of the blade is very close to the spine of the handle.
This is exactly why you don't fidget around...their not toys folks!! Glad it's nothing serious though.
BornIn1500
Post by BornIn1500 »
neuronic wrote:
Thu Sep 19, 2019 5:20 pm
fidgeting
Next you should try running with scissors. :D
neuronic
Post by neuronic »
Like I said, I didn't cut myself while fidgeting, I cut myself while holding the closed knife...
Just ckecked. When I run my finger along the back of the knife a little part gets between the scales and I can feel the edge, right behind the stop pin. If I apply some pressure I'm gonna cut myself...
Now that I think of it I do remember that some folks were stating exactly that problem (didn't the Shabaz, too? Have to check that...), but I would not have expected it to become a real thing for me...
Still don't consider it borderline dangerous, but here I am with a still open cut from a closed knife... :rolleyes:
neuronic
Post by neuronic »
BornIn1500 wrote:
Thu Sep 19, 2019 10:28 pm
fidgeting
Been there, done that... it's overhyped :p
standy99
Post by standy99 »
Very one sided
We need to hear the knife’s side of the story. :rolleyes:
MichaelScott
Post by MichaelScott »
When the Ikuchi was released there was a minor dust-up concerning the tip either standing a bit proud of the liners (very rare) or close enough to cut a finger passing over it and the liners. On my example, the tip was not proud, but close, by design I think. I could run my finger over the liners and tip normally without problem but if I pressed down enough flesh was pushed into the liners gap to contact the point. Perhaps this relates to your issue.
http://acehotel.blog
Team Innovation
jpm2
Post by jpm2 »
neuronic wrote:
Fri Sep 20, 2019 1:51 am
That would give me a good excuse to sharpen it down a bit.
