Your Delica 5
Larry_Mott
Re: Your Delica 5
#61
Post by Larry_Mott »
p_atrick wrote:
Thu Dec 20, 2018 1:24 pm
I don't know if I want to see a Delica 5 just yet. I personally think the Delica 4 is pretty great as is. That said, in 2020 I believe the Delica will be 30 years old. A special commemorative edition could be fun.
I'd much rather see a commemorative than a "upgrade"
Pelagic
Re: Your Delica 5
#62
Post by Pelagic »
abbazaba wrote:
Fri Nov 16, 2018 10:20 pm
If it happens I'm hoping for something like a mini Police 4, but this Boomer52 mod fits my hand very well..
Thank you for posting. My delica 5 would be something like this.
But my opinion doesn't count, I'll never buy a delica (as it is).
Pancake wrote:
Wed Aug 14, 2019 10:20 pm
Are you a magician? :eek:
Nate wrote:
Thu Apr 04, 2019 4:32 pm
Doeswhateveraspidercan wrote:
Sat Jun 15, 2019 9:17 pm
You are a nobody got it?
lonerider1013
Re: Your Delica 5
#63
Post by lonerider1013 »
I like the suggestion of a wire clip.
Beyond that the only thing I'd like is a bigger hole, like the 14mm one I made on mine...
I understand some folk want linerless. I like the liners so that's no prob for me.
Lonerider
"A fool's blade may be sharper than his brain"
“Learn to ride a bicycle. You will not regret it if you live." - Mark Twain
lonerider1013
Re: Your Delica 5
#64
Pelagic wrote:
Thu Dec 20, 2018 3:21 pm
That knife is also very nice though! What is it?
Lonerider
Re: Your Delica 5
#65
lonerider1013 wrote:
Fri Dec 21, 2018 7:33 am
Lonerider
https://www.bladeforums.com/threads/spy ... o.1583074/
lonerider1013
Re: Your Delica 5
#66
Wow!
Woodpuppy
Re: Your Delica 5
#67
Post by Woodpuppy »
I have a couple extra Delicas I “accidentally” traded for. I may B52 one of them, I love the mini para scales.
steelcity16
Re: Your Delica 5
#68
Post by steelcity16 »
deep carry wire clip, jimped finger choil, blacked out plain edge variation
Re: Your Delica 5
#69
Not much to improve for me in the Delica, MY Delica 5 should definitely:
- NOT feature a choil, but keep the hand closer to the edge in a regular grip (choking up on the Ricasso or even the edge is no problem at all, and there are SO MANY finger-choil-Spyders already...)
- keep the regular hourglass-clip
- BUT: make the blade longer, so it fills ALL the length of the handle when the knife is closed and give the knife more actual egde by doing so (I am aware of that this would make the Delica not a legal carry anymore in certain areas).
steelcity16
Re: Your Delica 5
#70
awa54 wrote:
Sun Nov 18, 2018 11:58 am
I'd buy a larger Worker with a Delica blade and wire clip in FRN :D
Hmm, I would take the opposite! A TiCN coated Worker blade in an Olive Green FRN Delica handle with a wire clip and spine/choil jimping. A Worklica if you will! :D With all of the interesting blade shapes (waved, hawkbill, wharncliff, shorty kahr arms blade, etc) being fit into Delicas, Dflies, Enduras and more, why not give this one a shot!??! It was the one that started it all, and it is still a great shape. I would buy a Worker LW in a second. A Worker LW Salt in PE H1 and SE H1 would be even cooler! :D
Woodpuppy
Re: Your Delica 5
#71
Post by Woodpuppy »
steelcity16 wrote:
Fri May 17, 2019 2:42 pm
🤔 now ya got me thinking.
StuntZombie
Re: Your Delica 5
#72
Post by StuntZombie »
Just take the liners out and I'll be happy.
Chris
Re: Your Delica 5
#73
StuntZombie wrote:
Fri May 17, 2019 3:30 pm
If the linerless Delica still feels as sturdy as lets say the Native LW, I am with you!
Woodpuppy
Re: Your Delica 5
#74
Post by Woodpuppy »
Fri May 17, 2019 3:44 pm
Salt 2 is a linerless delica 4. I’ve found it to be sturdy enough. And rust proof!
cycleguy
Re: Your Delica 5
#75
Post by cycleguy »
I really like the Delica 4 as it is and don't see how it can be changed for the better or broader market appeal ... let's face it no one knife is going to be perfect for everybody, but the Delica 4 seems to be perfect for me so I'm leaving it as it is.
Since I own a dozen or so ... here are some things I would like to see that would get me to purchase more: 1) I did replace the finished clip with an unfinished clip after year's of use and I prefer it so unfinished clip from the factory would be good, 2) current FRN colors have been around a very very long time so I would like to see some new and exciting FRN colors swapped in the line-up including tacticool like khaki and coyote brown and such, 3) I also liked the satin finish on the Kahr Arms models and would like to see the same finish on one of the many regular production models, 4) I would like to see one of the many models offered in a black coated plain edge blade, 5) I would like to see one of the many production models offered with G10 handles, 6) I also would like to see one of the models offered with the wire clip everyone is mentioning, 7) I would like to see Delica sprints that feature all the interesting steels like you see on the PM2 ... yes I know it is Japan and US so not likely!!! My favorite is the Damascu/Foalage Green FRN and I would enjoy seeing other Damascus/FRN sprints.
For those that don't find the Delica ergos working for them ... I am wondering how you grip/hold the knife??? I hold the knife mostly on the flat of my finger between the knuckle nearest the fingertip and the next one down ... the knife slightly angles across the flats with the front of the knife tight to the first knuckle and the rear of the knife tight to the second knuckle but on the side nearest the palm. There is no other way I can grip the knife and have the ergos work for me except a reverse grip. I use a light firm grip and don't find the need for applying more grip pressure for the size of the knife and the things that I use it to cut (mostly light duty slicing). However, I can apply more pressure and still find the ergos working.
CG
Re: Your Delica 5
#76
cycleguy wrote:
Fri May 17, 2019 6:48 pm
CG
I try to hold it similar to how you describe but there is no where for my thumb to go that doesn't feel painful or awkward. The ergos work ok if I wrap my thumb around the handle but sometimee I prefer putting my thumb on the back for better control.
On a knife that works for me ergonomically, like the Police 4, there is maybe an inch or so between where my index finger goes and where my thumb extends to. On the Delica 4 there's only 1/10th an inch or so.
So I can try to use the thumb ramp and the base joint of my thumb is so cramped it's basically at a 90 degree angle. Or I can put it on the spine and it feels awkward because of the hump, and then my thumb alsp gets in the way of what I'm cutting.
One thing I've tried to do is to adjust my grip to give my thumb more space. Tilting the knife down and pushing it forward in my grip a bit. I've tried putting my thumb on first, positioning it on the thumb ramp so its comfortable, and only then wrapping my other fingers around the handle. But then I can't get the finger grooves to line up with my grip.
I suppose if I really wanted to try to make a Delica work for me I could only use it with my thumb wrapped around the handle, but after putting it on thumb ramps / blade spines for decades its a tough habit to break.
StuntZombie
Re: Your Delica 5
#77
Woodpuppy wrote:
Fri May 17, 2019 5:28 pm
Exactly. I know Sal has said there are no plans to make the Endura and Delica linerless, but that just means I'll have to keep pestering him and bringing it up until it happens.
Chris
rabbitanarchy14
Re: Your Delica 5
#78
Post by rabbitanarchy14 »
i actually feel it should be made like the df, so it will actually be a bigger df. add a choil fix the tip straight not tip down. leave the liners and colors. wire clip would be nice too.
192.168.0.1 -Para 3 G10 M390 Red, Dice XHP, Lil Native Rex 45 comp, Manix 2 M390 G10 BR, PM2 M390 DLC BL, PM2 k390 RGreen, Cat BD1N, Dragonfly 2 k390
Saving for - Lil Native K390, D'allara 3, UTX-70
Instruments- Kimber EVO, SA Hellcat, SW Shield Plus 9
TomAiello
Re: Your Delica 5
#79
Post by TomAiello »
Damasteel anniversary edition?
spyderwolf
Re: Your Delica 5
#80
Post by spyderwolf »
The difference would be 0.4 oz.I doubt anyone would be able to tell just by holding the knife.
Whenever there is any doubt, there is no doubt.
