The joke is on you ...
cjk
Post by cjk »
The joke is on you because I would totally buy this, though I realize that these serrations would be near impossible to grind outside of photoshop: :smlling-eyes :smlling-eyes :smlling-eyes
cjk
Re: The joke is on you ...
Post by cjk »
Probably the very first self defense pizza slicer.
p_atrick
Post by p_atrick »
Yeah, but does it run on bearings?
Do I even need to say I'm in?
cjk
Post by cjk »
Evil D wrote:
Tue Apr 01, 2025 12:09 pm
Just visualize sharpening that. I'm thinking I would hold it with one hand and carefully turn the wheel with the other hand. I might need a third hand to hold the sharpmaker base steady. Maybe I could use a foot? I'm pretty short.
I might need to mark it with a sharpie so I could tell when I've made three strokes.
Skar
Post by Skar »
How often would you realistically need to sharpen a pizza cutter?
I think your good to go .
Red Leader
Post by Red Leader »
What a silly idea, I dont get it at all.
We need to start with an exclusive in Magnacut at the very least!
cjk wrote:
Tue Apr 01, 2025 12:12 pm
You'd definitely need to hold it and sharpen sections at a time. Maybe they could drill some holes in the blade and provide a pin that holds the blade so you don't have to touch it while sharpening.
Skar wrote:
Tue Apr 01, 2025 12:16 pm
This is also a good point.
But really this is one time when serrations are probably the wrong edge for the job since you'll probably be cutting on a cutting board, so you'd get more points making contact than the scallops, so you'd sort of perforate the pizza instead of slicing it.
I'd still buy one though 🤣
depends on the volume. we sharpen ours every 3-4 weeks.
se would be atrocious for this in real life, lol
p_atrick
Post by p_atrick »
Tue Apr 01, 2025 12:35 pm
Vivi, what's the most difficult kitchen cutting utensil that you've had to sharpen? A mezzaluna?
CDEP
Post by CDEP »
I'd buy this so fast I'd warp spacetime.
Brian
p_atrick wrote:
Tue Apr 01, 2025 1:03 pm
Those aren't too bad. I've done them similar to a regular knife on benchstones, and have tried clamping them in a vice blade up and sharpening that way.
Most odd ball stuff isn't difficult to sharpen, you just have to think of a good approach.
For example, with pizza cutters I just tighten their screws down so they don't spin. Do 1/2 to 3/4 the blade, then loosen them up and rotate them and finish the section I didn't hit.
Just like with any other cutting tool, a sharp pizza cutter makes cleaner cuts with less effort.
Fri Nov 17, 2023 1:29 pm
here's something different. repairing a chipped robo-coupe blade with a dmt diafold.
zuludelta
Post by zuludelta »
I'm holding out for the inevitable S90V/Carbon Fiber Sprint run LOL
Seriously, though, I had to double-check the calendar when I saw this pop up on my IG feed this morning—it sounds like something Spyderco would actually make back in the Whale Rescue Blade days (though in BD1N instead of SPY27)
My most recent reviews:
Genzow HatchetHawk, Ikuchi, MicroJimbo
prndltech
Post by prndltech »
Is it dishwasher safe?
MNOSD 0006
xceptnl
Post by xceptnl »
KSF has a terrific sense of humor. Check out the OTB
https://www.knivesshipfree.com/knivessh ... back-auto/
Deepest carry clip
https://www.knivesshipfree.com/deepest-carry-clip/
And super special KSF3000 sharpening system
https://www.knivesshipfree.com/ksf3000- ... ng-system/
*Landon*
SpeedHoles
Post by SpeedHoles »
Put a fishing reel handle on it at the pivot!
Pocket circular saw is the newest EDC craze
Going back to Caly.
RustyIron
Post by RustyIron »
Periodically? Mine tends to roll the edges, and it disrupts my sense of balance in the universe. I don't make it as sharp as I would a knife, but I put a respectable edge on it. Part of the problem is that I'm cutting against stone, steel, or aluminum--something I'd never do with a regular knife. Nevertheless, I would welcome a pizza cutter made from something other than whatever they were melting down that day at the Chinese recycling center.
My first job was in a small town grocery store deli, and we made tons of pizza, it was actually really good for a deli. We always used the big 20 inch Sani-Safe pizza knife, but it was also used for other cutting chores so it got sharpened fairly regularly.
If I could make the money I make now working in a pizza place I probably would. It was the one food related job that was kinda fun.
Post by Doc Dan »
Is that made in Italy for Spyderco? Is it N680? It will stand up to corrosion very nicely if so.
