Para 3 LW CPM-15V Clip Reversal?
Omak1
Post by Omak1 »
I just purchased a new Para 3 LW in 15V. I'm left-handed and tried to remove the screw holding down the wire clip. The screw won't loosen it just spins and the other side is just a smooth head. Other than sending it in to Spyderco is there something I can try to loosen the screw? I have a heat gun and a soldering iron but don't want to cause any damage.
Alan in Omak, WA
Omak1 - In Omak WA, Okanogan County
Jumpin'Spyder
Re: Para 3 LW CPM-15V Clip Reversal?
Post by Jumpin'Spyder »
I had the same issue with my beloved k390 Urban. Probably a matter of threadlocker, I solved applying a hot solder tip to the screw head till heating it, when Loctite melted...unscrewed all without any problem. Don't worry about damaging, just apply the solder the right time (about 30-40 seconds, probably less)
8th_Note
Post by 8th_Note »
Omak1 wrote:
Sat Mar 29, 2025 1:31 pm
Alan in Omak, WA
I find that it helps to get the barrel in a bind. Try putting a very thin screwdriver between the scales near the barrel, and press the handle down on the edge of a desk while you loosen the torx screw. Often just that little bit resistance will be enough to break the screw loose from the barrel
Omak1
Post by Omak1 »
Jumpin Spyder, 8th Note
Thank you both.
I'll try to jam the barrel first and if that doesn't work out I'll try my soldering iron
Alan in Omak, WA
3
Omak1
Post by Omak1 »
I tried both suggestions of putting the barrel nut in a bind and also heating the torx screw with my soldering iron tip. No bueno.
I sent the knife in for warranty service to reverse the clip. Too bad they could have had barrel nut with a torx head or in a "D" shape like the Endura.
It's sorta goes against my grain to pay $160 for a knife and then almost another $20 for shipping and insurance to reverse the pocket clip so I can carry my knife.
Pacu0420
Post by Pacu0420 »
Omak1 wrote:
Sat Apr 05, 2025 11:43 am
I am having the same issue with the same knife. I would like to get a set of AWT scales and a deep carry clip for it, but can't dissasemble the knife. I'm going to try the soldering iron method and see if that works. I really don't want to have to send it in just for a stuck screw.
Rezimus
Post by Rezimus »
Has Sal or anyone from Spyderco addressed why they keep the stock clip tip down after all these years? I havnt done a study but get the feeling 90% of people reverse it immediately upon arrival while sweating to make sure they dont strip the loctited t6.w
A person walks into 101 Flavor Matter Separator shop and asks, "Hey, what happened to the other 27 flavors?" The person behind the bar replies, "They did not taste enough like iron for our licking. - ykspydiefan
