What grit are spyderco blades finished to at the factory?
I'm planning on hand sanding my pm2 in s90v to a mirror finish. I've heard its a hard steel to sand so I'm not trying to do more work than is absolutely necessary. With that being said, I'm hoping someone can tell me at what grit spyderco finishes their pm2 blades?
Re: What grit are spyderco blades finished to at the factory?
Hi Ksunderman,
Welcome to our forum.
Are you planning to sand he edge or the blade?
I might be preaching to the choir here, but when I’m porting engines and want a mirror finish on my exhaust port I use a Foredom (you can use a Dremel or even bodge a regular drill into this role) with a purple scouring pad bit loaded with brasso, then a soft buffing bit. It gets you a mirror finish really quickly, but more importantly it allows you to carefully work on just the areas you want without any overlap. Another option is to put some painter’s tape along the edge (I find Frog Tape excellent), then trim off the excess before sanding.ksunderman94 wrote: ↑Sat Jan 13, 2024 12:02 pmI'm planning on hand sanding my pm2 in s90v to a mirror finish. I've heard its a hard steel to sand so I'm not trying to do more work than is absolutely necessary. With that being said, I'm hoping someone can tell me at what grit spyderco finishes their pm2 blades?
I don’t know if that is helpful. Good luck on your project
- Al
Work: Jumpmaster 2
Home: DF2 K390 Wharncliffe/DF2 Salt H1 SE and K390 Police 4 LW SE/15V Shaman
Dream knives -
Chinook in Magnacut (any era)
Manix 2 XL Salt in Magnacut
A larger Rockjumper in Magnacut SE
Work: Jumpmaster 2
Dream knives -
I've read that the grit/scratch pattern on Spyderco Mules is in the 180-220 range.
Anybody know if the grit/scratch pattern on PM2s are different?
I’m not sure why the existing blade finish matters. Silicon carbide is at least twice as hard as that steel and will grind it down just fine.
Some inexpensive diamond plates (like $15 on Amazon) may help make the low grits go faster. I think I would start with 400 grit and go up from there until I run out of diamond grits and then finish with 2k, 3k, 4k, 5k paper.
For a blade that will actually see use this is all a terrible idea. You’ll see every scuff on that mirror.
Have you ever done a hand satin finish before?
If not, S90V is just about the worst possible steel to start with.
Currently testing: M398, D3, SLD-Magic
Favorites: 10V, s90v
Wishlist: S290, Vancron, S125V, K890
18 Spydies, 15 steels
13 Maxace, 9 steels
13 Maxace, 9 steels
