Native 5 Salt SE or PE?
Hi everyone,
I know this so subjective but I’m on the fence about which Native 5 Salt to get? I want to get the LC200 but am on the fence. I have one Native 5 in a PE (Rex) already, and my other Salts happen to be SE (hawkbill lady, manbug, dragonfly)
Thanks everyone
Thanks everyone
- Manixguy@1994
Re: Native 5 Salt SE or PE?
I would try the PE since you have a variety of SE already . MG2
Gotta' disagree with MG2. You need to balance your Native 5 collection by getting one in SE. I have five Native 5s: 2 PE (M4 & Maxamet), 2 SE (S35VN & Magnacut), and 1 CE (Never Summer LC200N).
- Manixguy@1994
No worries here buddy . That is a very good point . MG2
Buy two….a serrated LC200N and a plain edge MagnaCut, then you’ll be Native set!
SE.
I think SE shines in longer blades, so for a Native sized knife I'd be more inclined to go with PE.
And with Vivi's low grit sharpening technique, you'll have the best of both worlds.
I dunno I'd say the exact opposite, small blades benefit from serrations because they literally add edge length and cutting aggression. Small blades suffer from less space to make slicing motions, but serrations are slicing 99% of the time.
An easier comparison here is a PE Ladybug vs a SE Ladybug. The difference is huge.
But, I'm also biased so
Evil D wrote: ↑Fri May 26, 2023 3:25 amI dunno I'd say the exact opposite, small blades benefit from serrations because they literally add edge length and cutting aggression. Small blades suffer from less space to make slicing motions, but serrations are slicing 99% of the time.
Agree with this line of thinking. The SE lil native really shines. Compact blade with surprising cutting ability.
- cabfrank
Given your other Salts, I'd get SE, then get something smaller in PE if you want.
After using SE edges and after learning to sharpen them on the sharpmaker, that is all I am going to buy in a spyderco!
Can someone tell me if the Native 5 Salt has titanium pocket clip? Just like the japan Salt models. Thanks
Same from my perspective. SE on a short blade really makes that short blade more capable.dan31 wrote: ↑Sat May 27, 2023 9:25 amEvil D wrote: ↑Fri May 26, 2023 3:25 amI dunno I'd say the exact opposite, small blades benefit from serrations because they literally add edge length and cutting aggression. Small blades suffer from less space to make slicing motions, but serrations are slicing 99% of the time.
Manbug Salt and Lil Native are the 2 shorter blades that I have preferred SE.
