Z-CUT serrations
buckthorn
Z-CUT serrations
Post by buckthorn »
I've been using Spydercos since 1989 when I started with a Worker. When the kitchen knives were introduced I added them as well. A couple of years ago I purchased a pointed tip, serrated Z-Cut and have been very pleased with it. I recently ordered another from an authorized dealer, accepting that the only option for a serrated blade was the round tip. I ordered one and it arrived today but I was surprised to find a much more mild, uniform serration pattern. Has anyone used both types of serrations and able compare the performance of the two patterns? Thank you.
Cl1ff
Re: Z-CUT serrations
Post by Cl1ff »
The blunt tip is more like a bread knife to me and are a little less aggressive, but they are still sharp and will cut just about anything. I'm not really sure why the regular serrated ones were discontinued.
Nature’s teeth have been cutting for hundreds of millions of years and counting :cool:
Post by JD Spydo »
The serrations on Spyderco's kitchen knives are more of a rounded/wavy type of serration pattern which are good for food applications. However I've found a few utility type jobs where those rounded/wavy type serrations seem to have certain advantages.
Even as super expensive as many of the Japanese and German culinary blades are I still regard Spyderco's kitchen/culinary blades to be the best available. I still use the old K-05 & K-04 models I've had since about 2003. Yep if it isn't broke then I don't try to fix it. I love lots of the older Spyderco models from that era.
Spyderco's kitchen blades are as unique as many of their folders and specialty knives.
Dnwrghtsr
Post by Dnwrghtsr »
I absolutely love my z-cut. Best all around kitchen knife I have ever owned.
Post by Doc Dan »
That Z-Cut rocks in the kitchen! Awesome little knife. I'd like to have a shorter version, as well.
Bill1170
Post by Bill1170 »
My serrated Z-cut is the go-to in the kitchen for tricky cuts, often involving packaging. The wonderfully thin blade does suffer from steering and deflection in firmer foods, however, thanks to the chisel grind of SE.
Ramonade
Post by Ramonade »
I have both a pointy and blunty SE Z-Cut. and yes the serrations are different like you mentionned. I prefer the ones on the blunt tip Z-Cut, it cuts tomatoes like a laser ! But except for tomatoes, it's kind of the same cutting experience for both configurations :open-grin
