They do not fit exactly in the Weber, so I usually cut the 4 corners and shape them to fit. This was the result after pierce-cutting the corners of a doubled-up alu foil drip pan:
Did I scratch the DLC coating? It sure looks so, but nope. This cleaned of completely with a kitchen scrubby and Jif/Vim cleaner. Of course the aluminium is a lot softer than the DLC coating, so you would not expect it to damage the coating. DLC is good stuff and cleans up nicely.
Have you scratched your DLC only to find out later that the "scratches" were material transfer, and it cleaned off completedly?
