Hello,
How would you go about getting a rusty knife to be good and loose again? It's a one-hand open one and it used to be really easy to just flick it out. I've used WD-40, got the major rust off the thing, and got it much improved, but it's still not really fast and smooth and loose like it was.
Thank you!
Rusty knife repair
Re: Rusty knife repair
I would use a product called Evapo-Rust to remove the existing rust, flush it and oil it again. This assumes it is a knife that cannot be disassembled. If you can disassemble it, do that first, then soak the parts in Evapo-Rust. Depending on how deep the rust penetrated the steel, you might have a lot of careful sanding to smooth out the steel.
Pictures would help people give you a better idea of what is possible, of course.
Good luck with your project!
Thanks JR. I didn't knkw about evapo-rust. Not that I need it, but that's good to know.
Thank you, I appreciate it. That helps a lot.
