Anyone think this is functional
akapennypincher
Post by akapennypincher »
Or pricy❓ Why ? Keep getting email advertising.🤯
https://www.bladehq.com/cat--BRNLY-Cypo ... qtep8lzp05
JRinFL
Re: Anyone think this is functional
Post by JRinFL »
I consider all of those as over-priced toys. In some places, you'll get hard time as they are likely considered in the same vein as brass knuckles.
Ric
Post by Ric »
Illegal in many places.
Limited buyers might drive the price.
I follow Brian from PNW Toast and would like to get one at some point. Unfortunately, they are hard to get ahold of - you've got to raffle your way in.
This looks similar. Sure, it might work as a "knuck," but I'd bet you use it a lot more often as a bottle opener or worry stone.
akapennypincher
Well we are all superstitious I have some Pebble that came from Japan that it is rumored they are good luck.
Cost zero, life has been lucky, but also do get it some help with work ethic.
James Y
Post by James Y »
From what I saw in the video of it, I’m not sure it could even be safely used as a knuckle, if someone were so inclined. You’d probably end up hurting yourself more if you used it that way.
As far as would I want one? Not really. If I need a bottle opener, I have one on my SAK. But I can see it as something others might want as pocket jewelry, a unique, handy little tool, as something to fidget with, etc.
Post by The Deacon »
As a SD tool, it's probably not very functional and, as others noted, potentially illegal. As a bottle opener, I'm fairly confident that it will open a bottle every bit as well as this $1 one.
aicolainen
Post by aicolainen »
I really don’t see any use for this “tool” that wouldn’t be better accomplished by a different tool.
For its size, it’s almost comically useless. It’s a cap lifter and that’s it. An implement you hardly need anymore anyways and is easily improvised if you ever do.
No disrespect to those who like it, or like the designer and want to support him. Sometimes we just like something and no amount of reasoning can change it.
It’s not for me though.
yablanowitz
Post by yablanowitz »
It is definately a functional tool for seperating fools from their money.
akapennypincher
yablanowitz wrote:
Wed Oct 12, 2022 6:47 pm
Think you got award coming.🏅if anyone want real deal good luck, GET LICKY RABBITS FOOT.
So Rabbit gave their life so you can have good luck, not LUCKY FOR RABBIT.😆
Post by Doc Dan »
That is just an expensive item to fill your pocket with more junk. Forget it.
standy99
Post by standy99 »
Instagram toy.
Seen them for under $50 by about 10 or so Instagram makers.
